There is only one result for “pooled coefficient variation” from Google (searching with the words within quotation mark). It is obvious that “pooled coefficient variation” is not a common term, it is likely a combination of“pooled” and“coefficient variation”. The definition of “coefficient variation”can be easily found from internet, and then the problem left is “pooled”.
It is also not difficult to find the information about“pooled”. For example, the information“When several small sets have the same sources of indeterminate error (i.e.: the same type of measurement but different samples), the standard deviations of the individual data sets may be pooled” can be found from http://science.widener.edu/svb/stats/descript.html
I think that “pooled” means “grouped together for analysis”(合并), the criteria of grouping would depend on certain statistical considerations.
Using ‘pooled, statistics’as keywords for searching may get a lot of information about “pooled”.
该帖子作者被版主
redanqi加 5积分,
2经验,加分理由:应助
