这是美国药典621中的内容,经理让我翻译,我不太会翻译,请哪位高手帮我纠正翻译一下。万分感谢! If syringe injection,which is irreproducible at the high pressures involved,must be used,better quantitative results are obtained by the internal calibration procedure where a known amount of a noninterfering compound,the internal standard,is added to the test and reference standard solutions,and the ratios of peak responses of drug and internal standard are compared. 如果要使用注射器注射剂(在高压下无法再生),通过内部校对规程会得到更佳定量的测定结果,在内部校对规程中,已知数量的非干扰化合物(内部标准品)被添加到测试品和标准参考溶液中, 可以比较药品和内部标准品的峰值响应比率.
