英文缩写 PEBA
英文全称 Polyether block amide
中文解释 聚醚嵌段酰胺
缩写分类 化学化工
其他:
1、This property data is a summary of similar materials in the MatWeb database for the category "Polyether Block Amide (PEBA)". Each property range of values reported is minimum and maximum values of appropriate MatWeb entries. The comments report the average value, and number of data points used to calculate the average. The values are not necessarily typical of any specific grade, especially less common values and those that can be most affected by additives or processing methods.
2、Polyether block amide (PEBA) resin history can be traced back as early as 1972 research initiatives searching for a non-plasticized ``soft'' nylon material. Actual commercialization of a polyether block amide polymer called PEBAX was launched in 1981.
By varying the nature and length of the polyether and polyamide blocks, a wide range of hardness characteristics-from rubbers (70 Shore A) to nylons (72 Shore D)-can be achieved. Altering the polyether/polyamide weight relationships results in changes in the flexibility of the polymer while imparting properties common to all …
该帖子作者被版主
hyheying加 3积分,
2经验,加分理由:积极应助
