4. What is the authors' approach or solution?
The authors solution includes:
- Object-based storage devices
- A globally known mapping function for locating file data
(instead of object lists)
- A scalable metadata manager that dynamically redelegates authority
for directory subtrees based on load
- A distributed autonomous system for managing the object stores
5. Why is it better than the other approaches or solutions?
It scales to petabytes, provides nearly linear performance improvements
as storage devices are added, degrades gracefully as storage devices are
removed, and provides very high performance.
6. How did they test their solution?
They ran parts of the storage system and observed their performance
under various workloads. Data performance was tested on a single object
store and on several object stores. Metadata performance was tested on
a large cluster.
