另外的参考资料(扩展):
Modified on-column interface for coupled high-performance liquid chromatography-gas chromatography and its application to the determination of levamisole in milk
References and further reading may be available for this article. To view references and further reading you must purchase this article.
Colin G. Chappella, Colin S. Creaser, a and Martin J. Shepherdb
aSchool of Chemical Sciences, University of East Anglia, Norwich NR4 7TJ UK
bMinistry of Agriculture, Fisheries and Food, Food Science Laboratory, Norwich Research Park, Colney, Norwich NR4 7UQ UK
Received 30 June 1992; revised 28 August 1992. Available online 20 November 2001.
Abstract
A modified on-column interface is reported for the coupling of high-performance liquid chromatography with gas chromatography, incorporated an adapted, commercially available multidimensional gas chromatography switching system. Novel features include cryogenic analyte focusing, total solvent exclusion from the analytical column and independent carrier gas supplies to the analytical
gc column and uncoated pre-column. The instrumentation was used for the determination of the veterinary anthelmintic drug levamisole in milk with analyte detection by both flame ionisation and nitrogen-phosphorus detectors. Detection limits for the assay were 2.2 ωg 1−1 and 0.4 ωg−1 by flame ionisation and nitrogen-phosphorus detectors, respectively. The assay was applied to a survey of fourteen milk samples from different dairy outlets.
Correspondence to: C. S. Creaser, School of Chemical Sciences, University of East Anglia, Norwich NR4 7TJ, UK.
