Range (μg/L) | Linearity | LOD (S/N = 3) (μg/L) | Retention time (min) | SD (min) | RSD (%) | Peak height (μS/cm) | Peak height SD (μS/cm) | RSD (%) |
130–390 | 0.9975 | 43 | 7.45 | 0.03 | 0.42 | 4.85 | 0.02 | 0.43 |
260–780 | 0.9999 | 46 | 9.19 | 0.07 | 0.81 | 3.54 | 0.05 | 1.35 |
410–1230 | 0.9999 | 72 | 12.00 | 0.08 | 0.73 | 3.87 | 0.05 | 1.32 |
310–930 | 0.9988 | 76 | 13.27 | 0.15 | 1.14 | 2.41 | 0.03 |
