表1 正交试验因素水平表
Tab.1 Test factor of orthogonal in level table
水平 | 因素 | |||||
A | B | C | D | E | F | |
萃取温度 | 萃取时间 | 搅拌速度 | 解吸温度 | 解吸时间 | 洗涤时间 | |
/℃ | /min | /rpm | /min | /℃ | /s | |
1 | 30 | 10 | 200 | 1 | 100 | 0 |
2 | 35 | 20 | 300 | 2 | 140 | 1 |
3 | 40 | 30 | 400 | 3 | 180 | 2 |
4 | 45 | 40 | 500 | 4 | 220 | 3 |
5 | 50 | 50 | 600 | 5 | 260 | 4 |
表2 六因素五水平正交试验数据表
Tab.2 The test data of orthogonal of six factors in five-level list
A | B | C | D | E | F | ||
因素 | 萃取温度 | 萃取时间 | 搅拌速度 | 解吸时间 | 解吸温度 | 洗涤时间 | 结果 |
/℃ | /min | /rpm | /min | /℃ | /s | ||
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1590 |
2 | 1 | 2 | 2 | 2 | 2 | 2 | 1464 |
3 | 1 | 3 | 3 | 3 | 3 | 3 | 2468 |
4 | 1 | 4 | 4 | 4 | 4 | 4 | 2619 |
5 | 1 | 5 | 5 | 5 | 5 | 5 | 2870 |
6 | 2 | 1 | 2 | 3 | 4 | 5 | 1918 |
7 | 2 | 2 | 3 | 4 | 5 | 1 | 2278 |
8 | 2 | 3 | 4 | 5 | 1 | 2 | 2037 |
9 | 2 | 4 | 5 | 1 | 2 | 3 | 2454 |
10 | 2 | 5 | 1 | 2 | 3 | 4 | 2355 |
11 | 3 | 1 | 3 | 5 | 2 | 4 | 1662 |
12 | 3 | 2 | 4 | 1 | 3 | 5 | 1979 |
13 | 3 | 3 | 5 | 2 | 4 | 1 | 3003 |
14 | 3 | 4 | 1 | 3 | 5 | 2 | 2574 |
15 | 3 | 5 | 2 | 4 | 1 | 3 | 2460 |
16 | 4 | 1 | 4 | 2 | 5 | 3 | 1466 |
17 | 4 | 2 | 5 | 3 | 1 | 4 | 976 |
18 | 4 | 3 | 1 | 4 | 2 | 5 | 1075 |
19 | 4 | 4 | 2 | 5 | 3 | 1 | 2354 |
20 | 4 | 5 | 3 | 1 | 4 | 2 | 1920 |
21 | 5 | 1 | 5 | 4 | 3 | 2 | 1394 |
22 | 5 | 2 | 1 | 5 | 4 | 3 | 1662 |
23 | 5 | 3 | 2 | 1 | 5 | 4 | 1255 |
24 | 5 | 4 | 3 | 2 | 1 | 5 | 1528 |
25 | 5 | 5 | 4 | 3 | 2 | 1 | 1982 |
K1 | 11011 | 8030 | 9356 | 9198 | 8591 | 11207 | |
K2 | 11042 | 8359 | 9451 | 9816 | 8737 | 9336.25 | |
K3 | 11678 | 9938 | 9856 | 9918 | 10550 | 10358.34 | |
K4 | 7891 | 11529 | 10083 | 9926 | 11122 | 8867 | |
K5 | 7821 | 11587 | 10697 | 10585 | 10443 | 9470 | |
2202.200 | 1606.000 | 1871.200 | 1839.600 | 1718.200 | 2241.400 | ||
2208.400 | 1671.800 | 1890.200 | 1963.200 | 1747.400 | 1867.250 | ||
2335.600 | 1987.600 | 1971.200 | 1983.600 | 2110.000 | 2071.667 | ||
1578.200 | 2305.800 | 2016.600 | 1985.200 | 2224.400 | 1773.400 | ||
1564.200 | 2317.400 | 2139.400 | 2117.000 | 2088.600 | 1894.000 | ||
R | 771.400 | 711.400 | 268.200 | 277.400 | 506.200 | 468.000 |
表3 方差分析表
Tab.3 Variance analysis table
因素 | 偏差平方和 | 自由度 | F比 | F临界值 | 显著性 |
萃取温度 | 2811488.240 | 4 | 12.040 | 4.110 | * |
萃取时间 | 2274397.040 | 4 | 9.740 | 4.110 | * |
搅拌速度 | 233504.240 | 4 | 1.000 | 4.110 | |
解吸时间 | 193887.040 | 4 | 0.830 | 4.110 | |
解吸温度 | 1055206.640 | 4 | 4.519 | 4.110 | * |
洗涤时间 | 693184.557 | 4 | 2.969 | 4.110 | |
误差 | 233504.24 | 4 | |||
总和 | 7495171.997 | 28 |
表1 正交试验因素水平表
水平 | 因素 | |||||
表2 六因素五水平正交试验数据表
表3 方差分析表
