In the chromatogram obtained with solution(1), the area of any peak due to the tenofovir monoester is not greater than twice the area of the principal peak obtained with solution(2)(1.0%). In the chromatogram obtained with solution(1), the area of not more than one peak, other than the principal peak, is greater than the area of the principal peak obtained with solution(2)(0.5%) and the areas of not more than two such peaks are greater than 0.4 times the areas of the principal peak obtained with solution(2)(0.2%). The sum of the areas of all peaks, other than the principal peak, is not greater than 5 times the area of the principal peak obtained in the chromatogram with solution(3) and any peak with an area less than 0.5 times the area of the principal peak in the chromatogram obtained with solution(2)(0.05%). Disregard any peak corresponding to the peak obtained in the chromatogram with solution(3) and any peak with an area less than 0.5 times the area of the principal peak in the chromatogram obtained with solution(2)( 0.05%).
在溶液1所获得的色谱图中,任何泰洛福韦单脂的峰面积不得超过溶液2主峰面积的2倍(1.0%)。在溶液1所获得的色谱图中,除主峰外,大于溶液2主峰面积的峰(0.5%)不得超过1个,并且大于溶液2主峰面积0.4倍的峰(0.2%)不得超过2个。除主峰外所有峰面积的总和不得超过溶液3主峰面积的5倍。忽略溶液3色谱图中相应的峰以及任何低于溶液2主峰面积0.5倍的峰。
感觉红色的部分是不是粘贴错误?不太好理解呀
