主题:【求助】AWWA 水管道方面的几个标准
浏览0 回复4 电梯直达
gdffjyb001
该帖子已被huigenghao设置为精华;
1ANSI/AWWA C205 Cement-Mortar Protective Lining and Coating for Steel Water
Pipe - 4 In. and Larger - Shop Applied
2ANSI/AWWA C206 Field Welding of Steel Water Pipe
3ANSI/AWWA C209 Cold-Applied Tape Coatings for the Exterior of Special
Sections, Connections, and Fittings for Steel Water Pipelines
4ANSI/AWWA C602 Cement-Mortar Lining of Water Pipelines 4-In and Larger - in
Place
5AWWA M-11 Steel Water Pipe - A Guide for Design and Installation
6ANSI/AWWA C 215-1999 Extruded Polyolefin Coatings for the Exterior of Steel Water Pipelines
灰米奇
ANSI/AWWA C205 -2007最新
AWWA C205-2000 钢制水管用水泥砂浆保护衬和覆层.大于等于4英寸(100mm).车间用    1.57MB
灰米奇
灰米奇
灰米奇
AWWA M-11-1989网盘下载,5.01MB
http://rapidshare.com/files/240351939/AWWA_M11-1989_-_Steel_pipe_Design_and_Installation.pdf 5,263 KB
2010/11/7 14:57:52 Last edit by eginzon
