7694E顶空进样器 | ||||||||||||
产品部件号 | 产品描述 | 数量 | 库存 | 单价 | 合计 | |||||||
2322590004 | Needle, Headspace transfer line 0.5mm OD | 1 | 4380 | 4380 | ||||||||
301-016-HSP | Needle for transfer line .05od Nickel | 1 | 400 | 400 | ||||||||
2322590005 | Needle, Headspace Transfer Line 0.7mm OD | 1 | 4337 | 4337 | ||||||||
301-015-HSP | Needle for transfer line .08 od Nickel | 1 | 519 | 519 | ||||||||
301-220-HSP | Needle Assembly, Siltek | 1 | 5108 | 5108 | ||||||||
301-013-HSP | Stainless Steel Needle | 1 | 1037 | 1037 | ||||||||
325-045-HSP | Zero Dead Volume Union | 1 | 366 | 366 | ||||||||
19258-20830 | NUT - TRANSFER LINE | 1 | 157 | 157 | ||||||||
19258-20870 | FERRULE, TRANSFER LINE | 1 | 143 | 143 | ||||||||
325-062-HSP | Union, FF, 6MB | 1 | 251 | 251 | ||||||||
325-132-HSP | Union Tee, 6MB-5 | 1 | 517 | 517 | ||||||||
325-185-HSP | Union Tee, Stainless Steel | 1 | 657 | 657 | ||||||||
3600500001 | Valve, Solenoid Vent Kalrez | 1 | 4155 | 4155 | ||||||||
3600500002 | Valve, Solenoid for Vial Pressurization | 1 | 2568 | 2568 | ||||||||
2321700003 | Sample loop, 1- ml, deactivated | 1 | 4420 | 4420 | ||||||||
321-055-HSP | Sampling Loop 1cc, Nickel | 1 | 2108 | 2108 | ||||||||
2321700004 | Sample loop, deactivated, 3mL | 1 | 3372 | 3372 | ||||||||
321-056-HSP | Sampling Loop 3cc, Nickel | 1 | 4201 | 4201 | ||||||||
301-212-HSP | Tube, needle-6 port valve,Siltek | 1 | 2546 | 2546 | ||||||||
301-169-HSP | Tube Needle Sampling Valve SS | 1 | 1020 | 1020 | ||||||||
301-170-HSP | Tube vent stainless steel | 1 | 1020 | 1020 | ||||||||
321-057-HSP | TUBE SENSOR 125MM LONG | 1 | 533 | 533 | ||||||||
321-002-HSP | Restrictor, Stainless Steel | 1 | 1756 | 1756 | ||||||||
301-211-HSP | Transfer Line, 1m ss deactivated | 1 | 11737 | 11737 | ||||||||
301-152-HSP | Optional Transfer Line | 1 | 8108 | 8108 | ||||||||
301-011-HSP | Transfer Line Std 80cm | 1 | 8197 | 8197 | ||||||||
301-205-HSP | Strain relief septum nut | 1 | 2141 | 2141 | ||||||||
301-017-HSP | Oven Adaptor, 10ml Vial, each | 1 | 414 | 414 | ||||||||
300-301-HSP | Tray adaptor, 10ml vial 25/PK | 1 | 2546 | 2546 | ||||||||
G1888-60701 | Headspace Leak Test Kit | 1 | 4231 | 4231 | ||||||||
5182-9733 | OQ/PV Headspace Sample | 1 | 1102 | 1102 |
气相色谱仪7890A | |||
说明 | 部件号 | 参考单价¥ | |
通用配件 | |||
手动进样器注射器10uL | 5190-1483 | 302 | |
自动进样器注射器10uL(6支/包装) | 5181-3360 | 2363 | |
平底顶空瓶10ml (100/包) | 5182-0838 | 326 | |
平底顶空瓶20ml (100/包) | 5182-0837 | 418 | |
银色钳口盖,20mm,PTFE/硅橡胶密封垫(100/包) | 5183-4477 | 626 | |
手动钳口封盖器,20mm | 9301-0720 | 2126 | |
手动钳口启盖器,20mm | 5181-1214 | 2440 | |
2mL透明螺纹瓶(5182-0714)带PTFE/红色硅橡胶隔垫的螺纹盖(5182-0717)各100个 | 5182D-0020 | 每套300元 (5套起定) | |
2mL棕色螺纹瓶(5182-0716)带PTFE/红色硅橡胶隔垫的螺纹盖(5182-0717)各100个 | 5182D-0030 | 每套350元 (5套起定) | |
开口扳手14mm | 8710-1924 | 179 | |
陶瓷片切柱器(4/包) | 5181-8836 | 178 | |
金刚石尖的柱切割器 | 420-1000 | 340 | |
样品前处理 | |||
固相萃取装置,12孔 | 5982-9110 | 7724 | |
固相萃取装置,20孔 | 5982-9120 | 9576 | |
SampliQ(C18) SPE小柱,1mL/100mg | 5982-1111 | 1288 | |
SampliQ(硅酸镁) SPE小柱,3mL/200mg | 5982-4332 | 722 | |
更多规格选择 请致电800-820-3278 | |||
进样口隔垫 | |||
低粘连BTO(耐高温,低流失)隔垫 11mm (50片/包) | 5183-4757 | 816 | |
低粘连高级绿色隔垫,11mm(50片/包) | 5183-4759 | 697 | |
低粘连长寿命隔垫,11mm(50片/包) | 5183-4761 | 948 | |
分流/不分流进样口配件 | |||
不分流衬管,单锥型,900uL去活,无玻璃棉(5/包) | 5183-4695 | 1393 | |
不分流衬管,单锥型,900uL去活,带玻璃棉(5/包) | 5183-4693 | 1456 | |
分流衬管,单锥型,870-uL去活,带玻璃棉(5/包装) | 5183-4701 | 1774 | |
分流/不分流衬管,单锥型,870uL去活,带玻璃棉(5/包) | 5183-4712 | 1267 | |
不粘连碳氟O形圈(10/包) | 5188-5365 | 143 | |
镀金密封板(1/包) | 5188-5367 | 388 | |
密封垫和柱螺帽 | |||
石墨密封圈(用于0.1~0.32mm内径毛细管柱) (10/包装) | 5080-8853 | 545 | |
石墨密封圈(用于0.53mm内径毛细管柱) (10/包) | 5080-8773 | 439 | |
通用柱螺帽(2/包装) | 5181-8830 | 306 | |
死堵头,手紧式 | 5020-8294 | 150 | |
填充柱进样口配件 | |||
0型圈,氟代烃(12/包装) | 5080-8898 | 171 | |
Vespel密封圈(10/包装) | 5080-8774 | 506 | |
柱螺母1/4-in.铜制(10/包装) | 5180-4105 | 163 | |
玻璃衬管,170-ul一次性使用(25/包装) | 5080-8732 | 427 | |
530 μm 柱接头,用于玻璃衬管 | 19244-80540 | 1581 | |
1/8 英寸柱接头,用于玻璃衬管 | 19243-80530 | 1312 | |
1/4 英寸柱接头,用于玻璃衬管 | 19243-80540 | 1873 | |
火焰离子化检测器(FID)配件 | |||
点火器点火塞组件(1/包装) | 19231-60680 | 513 | |
FID收集极组件(1/包装) | G1531-60690 | 2371 | |
专用毛细柱喷嘴(0.29 mm 内径的喷嘴) | G1531-80560 | 528 | |
喷嘴用于毛细管柱(0.29mm喷嘴内径) | 19244-80560 | 684 | |
喷嘴用于填充柱(0.46mm喷嘴内径) | 18710-20119 | 602 | |
FID清洁工具包(1/包装) | 9301-0985 | 479 | |
氮磷检测器(NPD)配件 | |||
Blos NPD 铷珠组件 | G3434-60806 | 7056 | |
NPD铷珠组件,白陶瓷 | G1534-60570 | 4516 | |
NPD铷珠组件,黑陶瓷,寿命长,对含磷化合物不拖尾 | 5183-2007 | 4566 | |
气路及气体控制配件 | |||
1/8英寸铜管,50英尺(15.24m) | 5180-4196 | 673 | |
黄铜螺帽,前后密封垫组合,1/8英寸(20/包) | 5080-8750 | 909 | |
黄铜两通接头,1/8英寸(2/包) | 5180-4127 | 259 | |
黄铜三通,1/8英寸(2/包) | 5180-4160 | 449 | |
水/氧捕集阱 | OT3-2 | 1291 | |
高容量水分捕集阱,1/8英寸,可再填充 | BMT-2 | 2909 | |
指示型玻璃水分捕集阱,1/8英寸,可再填充 | LGMT-2-HP | 1751 | |
高容量烃类捕集阱,1/8英寸,可再填充 | BHT-2 | 2909 | |
经济型烃类捕集阱,1/8英寸,可再填充 | HT200-2 | 1308 | |
高容量氧气捕集阱,1/8英寸 | BOT-2 | 2909 | |
经济型氧气捕集阱,1/8英寸 | OT1-2 | 1199 | |
指示型氧气捕集阱,1/8英寸 | IOT-2-HP | 1764 | |
大容量通用型气体捕集阱,1/8in.氦气 | RMSH-2 | 3226 | |
大容量通用型气体捕集阱,1/8in.氮气 | RMSN-2 | 3226 | |
ADM1000电子流量计(无气体种类限制) | 220-1170 | 7608 | |
高精度电子流量计(新) | 5067-0223 | 12967 | |
气体检漏计(新) | G3388A | 15643 |
液相色谱仪1100/1200 | |||
泵维护配件 | |||
泵维护工具套件: 含出口帽(1),PTFE滤芯(10), 活塞密封垫 (4), 出口金密封垫(1),入口过滤头(2)主动阀滤芯(1)(1/包装) | G1311-68710 | ¥5,119 | |
PTFE 滤芯——过滤白头,5/包 | 01018-22707 | 314 | |
冲洗阀/出口球阀出口盖,4/包 | 5062-2485 | 271 | |
冲洗阀/出口球阀镀金密封垫 | 5001-3707 | 299 | |
主动阀阀芯 | 5062-8562 | 1997 | |
主动阀阀芯(600bar 1200 SL) | G1312-60020 | 3705 | |
主动阀阀体(无过滤芯) | G1312-60025 | 3475 | |
蓝宝石活塞杆 | 5063-6586 | 1382 | |
活塞杆密封垫,石墨(反相)2/包 | 5063-6589 | 1026 | |
活塞杆密封垫,聚乙烯(正相)2/包 | 0905-1420 | 1324 | |
溶剂入口玻璃过滤头 | 5041-2168 | 475 | |
溶剂入口不锈钢过滤头 | 01018-60025 | 954 | |
透明溶剂瓶,螺口 1L 带实心盖 | 9301-1421 | 186 | |
棕色溶剂瓶,螺口 1L | 9301-1450 | 307 | |
溶剂瓶瓶头组件,用于螺口瓶 | G1311-60003 | 926 | |
溶剂管线(Teflon)5m | 5062-2483 | 315 | |
进样器配件 | |||
10ul手动进样注射器 | 5190-1484 | 372 | |
25ul手动进样注射器 | 5190-1494 | 372 | |
手动进样阀转子密封垫 | 0101-0623 | 902 | |
手动进样阀不锈钢定量管 | 依据不同体积而定 | ||
转子密封垫用于自动进样器G1313A/G1367A/G1329A | 0100-1853 | 836 | |
自动进样阀定量管 100ul | 01078-87302 | 1253 | |
标准针座用于自动进样器G1313A/G1327A/G1329A | G1313-87101 | 1069 | |
针头组件用于自动进样器G1313A/G1327A/G1329A | G1313-87201 | 684 | |
连接毛细管和接头配件 | |||
毛细管/接头启动工具包(内径0.17) | 5065-9939 | 6568 | |
PEEK管线,1.5m,内径0.18 | 0890-1763 | 247 | |
PEEK手紧式接头(10/包装) | 5063-6591 | 551 | |
手拧式聚酮接头可耐600 bar压力,10/包 | 5042-8957 | 745 | |
1/16英寸不锈钢接头,前后密封圈,10/包 | 5062-2418 | 1518 | |
不锈钢毛细管连接管线与接头, 9 cm, 0.17 mm内径 | G1316-87300 | 556 | |
不锈钢毛细管连接管线与接头, 18 cm, 0.17 mm内径 | G1313-87305 | 712 | |
不锈钢毛细管连接管线与接头, 7 cm, 0.12 mm内径 | G1316-87303 | 699 | |
不锈钢毛细管连接管线与接头, 18 cm, 0.12 mm内径 | G1313-87304 | 699 | |
更多管线选择 请致电800-820-3278 | |||
液相检测器配件 | |||
VWD(可变波长检测器)配件(G1314) | |||
VWD氘灯 (1000小时) | G1314-60100 | 6205 | |
长寿命氘灯(2000小时) | 2140-0813 | 9548 | |
DAD/MWD(二极管阵列检测器/多波长检测器)配件 | |||
氘灯 | 2140-0590 | 6787 | |
氘灯,长寿命 | 2140-0813 | 9548 | |
氘灯,长寿命 用于G1315A/B DAD 和 G1365A/B MWD | 5181-1530 | 9953 | |
氘灯,长寿命 用于G1315C DAD 和 G1365C MWD | 2140-0820 | 10019 | |
钨灯 | G1103-60001 | 1595 | |
样品过滤——注射式过滤器 | |||
再生纤维素,直径25mm,孔径0.2um 200/包 | 5185-5830 | 2342 | |
再生纤维素,直径25mm,孔径0.45um 200/包 | 5185-5831 | 2342 | |
尼龙,直径25mm,孔径0.2um 200/包 | 5185-5832 | 2509 | |
尼龙,直径25mm,孔径0.45um 200/包 | 5185-5833 | 2509 | |
PTFE,直径25mm,孔径0.2um 200/包 | 5185-5834 | 2526 | |
PTFE,直径25mm,孔径0.45um 200/包 | 5185-5835 | 2526 | |
其他配件 | |||
