主题:Guidelines for Keeping Lab Notebooks
浏览0 回复18 电梯直达
nikang3148
该帖子已被happyjyl设置为精华;
A laboratory notebook is a critical record events leading to patentable discovery. The information can help to establish dates of conception and reduction to practice and inventorship.
Do’s
#1 Do use bound books
  Use permanently bound notebooks
#2 Do sign and date
  Each notebook should be signed and dated on the inside front cover and each entry should be signed and dated. An independent witness, i.e., someone who understands the technology but will not be named as co-inventor of the invention, should sign and date each entry after the statement:“ Read and understood by __.”(The witness should preferably sign the entries on a contemporaneous or fairly contemporaneous basis, but entries can also be reviewed, signed, and dated on a periodic, e.g., weekly or monthly, basis.)
#3 Do use ink
  Notebook entries should be made in ink and in chronological order. Entries should not be erase or “whited out.” If an entry contains an error, a line should be draw through the error and new text should continue in the next available space.
#4 Do use past tense
  Use the past tense (e.g. “was heated”) to describe the experiments that were actually performed.
#5 Do explain abbreviations and special terms
  Explain all abbreviations and terms that are non-standard.
#6 Do staple attachments
  Attachments (e.g. graphs, computer printouts) should be permanently affixed in the notebook (e.g. by stapling) and both the attachment and the notebook page signed and dated. Attachments that cannot be attached should be placed in an envelope and the envelope attached to the notebook page. The envelope and page should then be signed and witnessed making reference to the attachment being placed in the envelope.
#7Do outline new experiments
When a new project or experiment is started, the objective and rationale should be briefly outlined, in a short paragraph or by providing a flowchart.
#8Do record lab meeting discussions
relevant discussions from lab meetings should be recorded including ideas or suggestions made by others. The names of the people making the suggestions should be documented.
#9Do provide detail
Record test descriptions, including preferred operation conditions, control conditions, operable and preferred range of conditions. And alternate specific materials; test device. Conclusions should be short and supported by the factual data. Opinions or speculation about the invention should be avoided.
#10 Do track notebooks
Ideally, each lab should maintain a catalogue of notebooks in which each notebook is assigned a number, and the name of the author of each notebook is recorded.
#11Do save completed notebooks
All completed notebooks should be indexed (e.g. by number, by author, by subject area) and safely kept in a central repository.
Don’ts
#12 Don’t leave blank spaces
Blank gaps between entries should be avoided. If a blank space is left on a page, a line or cross should be drawn through the blank space and the page dated to prevent subsequent entries.
#13 Don’t modify
Prior entries should not be modified at a later date. If data were omitted, the new data can be entered under a new date and cross-referenced to the previous entry.
#14Don’t remove originals
No original page should be removed from the notebook.
nikang3148
实验记录的指导
实验记录本是能引发具有开创性发现事件的关键要素。其中的信息能够有助于重现你的实验设想和总结归纳实施以及创新的步骤。
一定要做的
1.务必使用装订本
使用永久装订的记录本
2.  务必签字和标日期
每本实验记录本必须在首页署名并标上日期,每次的实验记录纸也要签字并标上日期。每个独立的观察员,指那些不作为合作者而署名,但是理解实验技术的人员,在实验记录纸上也需要的页末尾的声明“______已经阅读并且理解”中的空白处签字并标上日期。(观察员能够同时或者相对同时地在实验记录上签名,但是最好定期地再次翻阅实验记录,签字并标上日期,比如每周、每个月)
3.  务必使用墨水
实验记录纸上必须使用墨水按照时间顺序记录。记录不能用橡皮或者修正液涂改,如果实验记录中含有错误,则在错误上画线,在错误附近的空白处写上正确的内容。
4.使用过去时态
使用过去时态来描述每个实验步骤。
5.解释缩写和专业术语
解释每个非标准化的缩写和专业术语。
6.装订附件
附件(指图、计算机输出的数据)必须装订进实验记录本保存,并且每个附件和实验记录必须签字、标上日期。不能装订的附件要装进信封,将信封装订进实验记录本,信封和记录纸必须作上标记并签字,使其信封中的附件相对应。
7.概述新的实验
当进行一项新的计划或者实验时,使用简短的篇幅或者流程图简单叙述一下实验目的和原理。
8.记录实验室会议中的讨论
记录实验室会议中相关的讨论内容,包括他人的想法和建议,提建议的姓名也要标注出来。
9.记录实验的细节信息
记录实验说明,包括较好的操作条件、控制条件,以及可以操作和控制的条件的范围,还有需要预备的实验材料、测试仪器。结果必须简要而且能够得到事实数据的支持。避免个人主观的判断和推论。
10.检索记录
理论上说,每个实验室都有一个实验记录的目录,其中记录了实验记录本的编号和实验记录人的姓名。
11.保存用完的记录本
每个用完的记录本必须建立索引(通过编号、实验者或者学科领域),并且安全收存在中心仓库。
不能做的
12.不要留下空白
避免实验记录间的空白缝隙,如果一页上留有空白,在空白处要画上一条横线或者对角线,并且这一页标上日期,不能记录后来的实验内容。
13.不要修改
日后不能修改主要的实验内容,如果有数据遗漏,可以在新的日期的记录页上补上,并且和前期的实验构成交叉引用。
14.不要移除原始记录
非原始记录页要从记录本中移除出去。
happyjyl
我的理解是:实验记录本应设计成这样的格式:每一页都印有“Read and understood by  "的字样,每个独立的观察员(指那些不作为合作者而署名,但是理解实验技术的人员)在“Read and understood by  "字样的空白处签名并写上日期。实验记录本的设计应当满足定期复查的需要,比如说,每月复查一次的,由于每次复查都要签名并写上日期,实验记录本的设计就应该做到每一页印有12条Read and understood by  "。我觉得"The witness should preferably sign the entries on a contemporaneous or fairly contemporaneous basis, "意思是说每次定期复查应该在每个月的同一天,如果是每周复查,就应该在每周的同一天。
我的理解是:附件(如图谱和电脑打印的文件)
我的理解是:信封和记录纸必须作上标记并签字,使信封中的附件与实验记录本上的内容相对应。
我的理解是:preferred operation conditions-最佳实验条件,比如HPLC里的最佳流速;control conditions-需要控制的条件,比如程序升温;operable and preferred range of conditions-许可的实验条件的范围,超出这个范围则实验失败或不准确,比如某滴定反应用酚酞作为指示剂,酚酞的变色范围是PH8.0-10.0,则该反应的operable and preferred range of conditions之一就是PH8.0-10.0。
我的理解是:Prior entries是指先前的记录,而不是主要的记录。因为所有的实验记录在之后都不能修改。
我的理解是:实验记录本中的每一页原始记录都不能撕去。No在这里表示的意思是”不允许“,而不是”非“。用法同No Smoking(严禁吸烟)。
其它的我都同意楼主的翻译。
shxie
axun
nikang3148
nikang3148
Use permanently bound notebooks老师说是使用精装本,我不知道应该怎么看什么才是精装本呢?
nikang3148
Each notebook should be signed and dated on the inside front cover 是说签名还是作上标记啊?
happyjyl
我的理解是使用永久装订的笔记本。即每一页都是连续的,而不是活页本。
sign我觉得应该是指签名吧。因为一个笔记本的使用者只能是一个人,所以应该由使用者本人签名。
我在网上查了一篇美国法律关于Keeping Laboratory Notebooks的记录,其中一句如下:
The following guidelines should be followed with respect to all laboratory notebooks:
1.The notebook should have permanently bound pages which are consecutively numbered and should be used by a single engineer or scientist.
全文如下:
Proper Maintenance of a Laboratory Notebook
The United States laws implementing the general agreement on tariffs and trade (GATT) came into force on June 8, 1995. As a result, as of January 1, 1996, it has been possible for foreign inventors to establish a date of invention in a U.S. patent application by reference to knowledge
or use of the invention in a foreign country which is a member of the World Trade Organization (WTO), or activity with respect to it in a foreign country which is a member of the WTO. Since United States patents are awarded to the first person to invent, not the first applicant, an applicant's ability to obtain a patent for his invention may often depend upon how well he
documents inventive foreign activity with respect to his invention. This applies, not only to the situation in which an inventor becomes involve in an interference, but also when he wishes to avoid or "swear behind" a reference applied against an application by proving a prior date of invention.
Under the new law, it therefore becomes essential for foreign inventors to maintain an accurate and well-documented laboratory notebook.
2.Ideas, calculations and experimental results should be entered into the notebook as soon as possible, preferably the same date they occur, so that the laboratory notebook becomes a daily record of the inventor's activities.
3.All entries should be made in the notebook in permanent black ink and should be as legible and complete as possible. Do not use abbreviations, code names or product codes without defining them clearly.
4.Draw a line through all errors. Do not erase.
5.Entries should always be made in the notebook without skipping pages or leaving empty spaces at the bottom of a page. If you wish to start an entry on a new page, draw a line through any unused portion of the previous page.
6.Never tear out or remove a page from the notebook.
7.Each page should be signed with the inventor's full name and dated. No entry should be changed or added to after signature. If the inventor has any additional information or corrections, a new entry should be made.
8.Each page of the notebook should be witnessed, signed and dated by a colleague who understands the inventor's work. This should preferably occur daily and certainly no less frequently than weekly. The witness should not be a direct contributor to the work being reported.
9.If an additional entry is made between the initial and final pages recording an experiment, the entry should identify the page on which the previous entry for that experiment occurs.
10.When the laboratory notebook is completely filled and is no longer required for reference, it should be indexed and stored in a safe location and, thereafter, handled in accordance with the company's established record retention and destruction policy for such documents.
Some factors which reduce the value or credibility of your laboratory notebook:
illegible entries are totally worthless;
unsigned or undated pages are almost totally worthless;
notebook pages which have not been witnessed are almost as bad as unsigned and undated pages;
a long delay between the signing of the page by the inventor and the witness raises questions;
consecutive notebook pages which are not dated in chronological order raise questions;
missing notebook pages raise questions;
erasures and deletions raise questions -- instead, any later discovered mistakes should be corrected and explained on the next available blank page, referencing the page with the mistake.
In modern laboratories it is often the habit of engineers to maintain records of their work in computer files. We do not believe that computer files can provide sufficient evidence of invention. The reason for having invention records is to be able to prove the earliest date of invention. Since computer records can be updated and changed at will, and their dates are subject
to tampering, they cannot serve as evidence that their content was created at a particular time. With a bound notebook, it is clear that the work occurred in a particular sequence and was witnessed by others. Also, scientific experiments can be conducted on the ink and paper in a notebook to prove their age.
If bound notebooks have not been kept, written invention disclosure forms submitted by the inventors to their intellectual property departments may be the best available evidence. Therefore, they should be a complete description of the invention, dated and signed by the inventor. They should also be witnessed, as soon as possible, by someone capable of understanding
the invention.
It may be difficult and somewhat expensive for companies to maintain invention records in a bound notebook. As a result, this procedure may not be followed in many cases. Nevertheless, the new statute provides benefits to foreign inventors by at least allowing them to prove dates of invention as early as the submission of disclosures to their company's intellectual property department or domestic patent agents.
wrliao
lotus_sum
原文由 nikang3148 发表:
簽名並標注時間!
