分解一下,二相流动相的调整比三相的简单多了:
当流动相比例是50:50时,
1. Thirty percent of 50 is 15% absolute, but this exceeds the maximum permitted change of
±10% absolute in either component.
2. Therefore, the mobile phase ratio may be adjusted only within the range of 40:60 to 60:40.
当流动相比例是2:98时,
3. Thirty percent of 2 is 0.6% absolute.
4. Therefore the maximum allowed adjustment is within the range of 1.4:98.6 to 2.6:97.4.
