主题:询问:电热板的购买
浏览0 回复17 电梯直达
hotsonwood
大家给点介绍。
wangwuchen
这些小玩意可以到本网的仪器专栏查一下,本身技术含量不高,选一个正规点代理商询一下。
boywy000
我同意楼上的观点,我最近是在上海南铭买的,你有兴趣的话我可以给你他的联系方式~~
zengdeen
cricket
990015305
VWR-600系列磁力搅拌电热板
VWR* 600 Series Standard Hot Plate Stirrers
600系列磁力搅拌电热板
Ceramic or Aluminum Top Plate
Support Rod Holder
Electronic Stir Brake
Hot Top Indicator
UL and C-UL listed. CE marked
VWR Two-Year Warranty on Parts and Labor
Designed for general laboratory heating applications. Low-profile design conserves space and fits easily into most fume hoods. The front panel features easy-to-use controls that allow users to dial-in adjustments. Spill-resistant housing channels fluids away from the internal components. On the rear of the unit is a built-in support rod holder with locking knob.。
Microprocessor control regulates heat and speed, bringing samples to desired temperature quickly and accurately and providing consistent stirring at all speeds. Ramping feature slowly increases speed to avoid splashing, improve magnetic coupling, and provide excellent low-end control. Electronic stir brake quickly stops spin bar when stir function is turned off. Powerful continuous duty motor delivers dependable and reliable stirring. For additional safety, a hot-surface alert (“CAUTION HOT TOP”) illuminates when the temperature rises above 40°C (104°F). This alert remains on until the unit cools, even when the heater is turned off。
Choose from models with a ceramic or aluminum top plate. Ceramic top plates feature an easy-to-clean, chemical-resistant, reflective white surface. Durable aluminum top plates provide a more even heating surface and will not crack or chip。
技 术 指 标
产品型号 610-HPS 615-HPS 620-HPS 625-HPS 630-HPS 635-HPS
产品编号 12365-358 12365-364 12365-394 12365-400 12365-430 12365-436
台面材质 陶瓷 铝合金 陶瓷 铝合金 陶瓷 铝合金
温度范围 30 - 500℃ 30 - 400℃ 30 - 500℃ 30 - 400℃ 30 - 500℃ 30 - 400℃
温度稳定性 ± 3%* ± 2%* ± 3%* ± 2%* ± 3%* ± 2%*
磁力搅拌转速 60~1,200 rpm 60~1,600 rpm
速度稳定性 ± 2%
内部规格(宽x深) 10.2x10.2 cm 17.8x17.8 cm 25.4x25.4 cm
外部规格(宽x深x高) 22.9x15.2x8.6 cm 31.1x21.8x8.6 cm 38.7x29.5x8.6 cm
工作能力 600 ml 2,500 ml 6,000 ml
重量 2.5 kg 3.8 kg 5.4 kg
电源 230V/50Hz
*. 在低于100℃为±2℃,但其取决于环境和样品条件的限制。
订货信息: Units include a PTFE-coated stir bar and a detachable three-wire cord with US plug (230V units include a Euro-plug). The support rod and clamp kit includes a 45.7cm (18") long support rod, a thermometer/temperature probe extension clamp, a three-prong dual-adjust clamp, and a hook connector.。
产品编号 产品描述 人民币报价[注]
12365-358 610-HPS型磁力搅拌陶瓷电热板,220V/50Hz 5,600.00
12365-394 620-HPS型磁力搅拌陶瓷电热板,220V/50Hz 6,600.00
12365-430 630-HPS型磁力搅拌陶瓷电热板,220V/50Hz 8,300.00
12365-364 615-HPS型磁力搅拌陶瓷电热板,220V/50Hz 6,300.00
12365-400 625-HPS型磁力搅拌陶瓷电热板,220V/50Hz 7,500.00
12365-436 635-HPS型磁力搅拌陶瓷电热板,220V/50Hz 9,300.00
11301-110 支架和夹子套件 1,250.00
02162890847陈先生
chprince
happy2006
shuqin_li
电热板的温度控制不是很好,且不能耐受强酸碱的腐蚀,为什么不考虑一款比他更耐用实用价值更高的石磨消解系统呢,原理与平板消解是一样的,可功效就大不相同了,想知道更多的信息请致电13583287195青岛
popo
原文由 shuqin_li 发表:
不能耐受强酸碱的腐蚀?这个应该可以从面板材料上进行选择吧?石磨消解系统?给点资料看看?puanzy@126.com 谢谢!
cder8
能不能发点资料过来呢?chemhu@126.com
原文由 shuqin_li 发表:
