原文由 天黑请闭眼(shxie) 发表:
3. 另外,每种溶剂的毒性和残余程度需要认真考量,按照药典规定和"残余溶剂”第467条专门要求的限用溶剂,要用相关内容给出的一般方法或者其它适用方法评价。
原文由 poorlittle(poorlittle) 发表:原文由 天黑请闭眼(shxie) 发表:
Suggestion : 第467条"残余溶剂”
Is it possible that "In addition, the toxicity and residual level of each solvent shall be taken into consideration, and the solvents (shall be ???) limited according to the principles defined and the requirements specified in Residual Solvents <467>, using the general methods presented therein or other suitable methods."
If it is read as “the solvents shall be limited”, my interpretation would be :
并根据A及应用B来规限溶剂.
Where
A = [(the principles defined) and (the requirements specified)] in Residual Solvents <467>
B = the general methods presented therein or other suitable methods
