主题:【原创】外贴式超声波液位开关
浏览0 回复3 电梯直达
watey
产品简介
我们研制生产的wo-b型非接触式超声波液位开关,是一种新型的液位报警测量装置,它解决了厚壁贮罐液位报警测量的难题。该液位开关主要由超声探头和二次表组成。探头表面紧贴在油罐或压力球型贮罐罐壁外侧需要限位的相应位置,利用超声技术,在液位到达该位置时,产生开关量信号,再通过电缆,将此信息传送到位于安全区的测试仪表(二次表)。
产品详细信息
外贴式超声波液位开关
outside-attached ultrasonic liquid-level switch
■液位开关领域新霸主:wo-b外贴式超声波液位开关
■Fluid switch domain new overlord:wo-b Outside-attached ultrasonic
liquid-level switch
◆ 罐外安装,不开孔,不动火,不损伤罐体,可不停产安装,不停产维修;
◆ 非插入式测量,与介质的压力、比重、有无腐蚀性无关,适应面广;
◆ 外贴测量,对罐内或装置内介质不产生干扰,无污染、无泄露、无腐蚀;
◆ 适用于石化常压或高压罐及装置、对卫生要求严格的食品罐、医药卫生罐及强腐蚀性罐,是一种环
保型仪表;
◆ 配有多种探头,既可测常温罐,又可测高温罐(最高温度300℃)。
◆ Outside the pot installs, the opening, does not get angry, does not damage the shell of tank, but does not
suspend production the installment, does not suspend production the service;
◆ Does the non-jack-in survey, with the medium pressure, the proportion, whether there is corrosiveness have
nothing to do with, the adaptation suRFace is broad;
◆ Outside pastes the survey, the medium does not have the disturbance to the pot in or the installment, does
not have the pollution, not to have the revelation, not to have the corrosion;
◆ Is suitable for the petrochemical atmospheric pressure or the high-pressured pot and the equipment, to the
hygienic request strict food pot, the medicine health pot and the strong corrosive pot, is one kind of
environmental protection measuring appliance;
◆ Has many kinds of probe heads, both observable normal temperature pot, and observable high temperature
莞城.XiShui
非接触式超声波液位开关,是一种新型的液位报警测量装置。
yuduoling
watey
原文由 yuduoling(yuduoling) 发表:
现在有哪家单位在用的?可不可以提供一下资料?
基本都在石化罐区。用的非常多,几个典型的,广西石化钦州港、广东茂名石化、镇江炼化、白沙湾油库、青岛大炼油、大连炼油基地(N家)、天津港罐区、大庆炼化、吉化、宁炼、新疆吐哈油田、等等等等
请发信息给我邮箱wangzhen6541@163.com,把资料发给您。
