主题:【The First Fost On March 30】 For Help
浏览0 回复12 电梯直达
金水楼台先得月
  The answer is      Why?
该帖子作者被版主 影子5积分, 2经验,加分理由:第一主题贴
yuduoling
The answer is C.
该帖子作者被版主 hyheying1积分, 2经验,加分理由:参与应助
symmacros
The answer is C.maximum length per piece as different delivery demands diffirent maximum length piece.
该帖子作者被版主 hyheying2积分, 2经验,加分理由:参与应助
金水楼台先得月
原文由 symmacros(jimzhu) 发表:
i
but the standard answer is B! I managed to grasp it ,but failed.Can you tell me why  the answer is B?
天黑请闭眼
TOFEL?long time no see such problems.......
Good moring, bros. Spring is coming to Hokkaido, almost 80% snow melted recently. The smell of fresh and warm air is really awesome. Do you have any schedule on travelling?
2011/3/30 8:26:41 Last edit by shxie
天黑请闭眼
原文由 金水楼台先得月(albert800922) 发表:
i
Really? I also think C is the right option. Maybe the answer is a mistake.
symmacros
i
This may be a trick, so I failed to answer at first as a wrong understanding.
Actually answer B,  maximum length per piece plus girth per piece includes  maximum length per piece and  maximum height per piece. The size is important. But how about  maximum weight per piece, I don't understand?
arvid2007
The answer is C。Because the others are the same price.
阿迈
I think the answer is C.
If we want "3 day freight",the max. length per piece is shorter than "1 day freight".
小鸟飞翔
C,maximum length per piece
小M
答案是C啦,因为从表中可以看出A\B\D选项各自的限制是一样的,这道题目很容易吧……
