原文由 chauchylan(chauchylan) 发表:
这与LA的仪器参数有很大的关系,对其影响最大的有LA的波长,脉冲宽度,单个脉冲的能量,这些参数影响LA的分辨率
脉冲宽度为 10-20纳秒的激光器,波长的影响很大;
脉冲宽度为 60-400飞秒的激光器,波长的影响很小。
Femtosecond pulses deposit the energy onto the target material faster than thermal diffusion transports the energy away from the ablation area. This allows ablated materials to be heated to much higher temperatures compared to nanosecond laser pulses. The timescale of this process is in the subpicosecond (10-12 sec) range, in contrast to thermal diffusion of 10-11 sec.
