V
vacancy chromatography,空穴色谱法
vacuum,真空;负压
vacuum accumulator,真空贮气筒
vacuum correction,真空修正
vacuum drying chamber,真空干燥箱
vacuum evaporator,真空镀膜台
vacuum fusion gas chromatography,真空熔融
气相色谱法
vacuum gauge,真空表;真空规管
vacuum system,真空系统
vacuum transducer [sensor],真空[负压]传感器
vacuum valve,真空阀门
validity check,有效性检验
validity event,有效事件
valley,谷
Vallot helio-thermometer,瓦劳特日光温度表
value analysis,价值分析
value engineering,价值工程
value (of a quantity),(量)值
value of image shift,图象漂移量
value of scale division,标度分格值
value of scale mark,标度值
values transfer,量值传递
valve,阀
valve body,阀体
valve capacity,阀容量
valve outlet Mach number,阀出口马赫数
valve plug,阀芯
valve seat,阀座面
valve shaft,阀轴
valve sizing,阀尺寸计算;阀口径计算
valve stem,阀杆
valve stem position transmitter,阀位发送器
valve stem unbalance,阀杆不平衡力
vane,阀板;方向标
vapour concentration,水汽浓度
vapour pressure,水汽压
vapour tension,水汽张力
vaporizer,汽化室
vaporizing heat,气化热
variable,变量
variable-angle internal reflection element,可变角度内反射元件
variable angle probe,可变有探头
variable area flowmeter,变面积流量计
variable-area methods,可变面积法
variable gain,可变增益;可变放大系数
variable gain method,可变增益法
variable-head flowmeter,可变压头流量计
variable magnetic-resistance type transducer,变磁阻式传感器
variable pressure,变化压力;变压
variable standard capacitor,可变标准电容器
vaiable structure control system,变结构控制系统
variation (due to influence quantity),(影响量引起的)变化量;变差
variation in testing temperature,试验温度波动度
variation in the indicating value,示值变动值
variety,品种
varistor,电压敏电阻器
vectopluviometer,雨向计
vector averaging current meter,矢量平均海流计
veiling glare,杂光
veiling glare coefficient,杂光系数
velocity,速度
velocity-area methods,速度面积法
velocity distribution,速度分布
velocity error,速度误差
velocity error coefficient,速度误差系数
velocity feedback,速度反馈
velocity focusing,速度聚焦
velocity limiter,速度限制器
velocity measure thermistor,测速热敏电阻器
velocity of approach factor,渐近速度系数
velocity pickup,速度传感器
velocity transducer [sensor],速度传感器
velocity type water meter,速度式水表
vena contracta,缩流断面
vena contracta pressure tappings,缩流取压口
vent holes,排气孔
ventilated psychrometer,通风干湿表
ventilated thermometer,通风温度表
ventilation rate,换气量
ventilator,通风器
Venturi nozzle,文丘里喷嘴
Venturi tube,文丘里管
Verification,检验;检定
verifier,校对机
verify,校对
vernier,游标
vertical angle,竖直角
vertical axis,竖轴
vertical balancing machine,立式平衡机
vertical current flow method,直角通电法
vertical extent of a cloud,云的垂直厚度
vertical limit,垂直极限
vertical scanning,帧扫描
vertical tail,垂直翼
vertical temperature profiler radiometer (VTPR),垂直温度剖面仪
vertical visibility,垂直能见度
very low frequency electromagnetical receiver,甚低频电磁仪
VF presentation,视频显示;检波显示
vibrating reed instrument,振簧系仪表
vibrating sample magnetometer,振动样品磁强计
vibrating viscometer,振动粘度计
vibrating wire [resonant wire] drawing force meter,振弦式拉力计
vibrating wire [resonant wire] force transducer,振弦式力传感器
vibrating wire [resonant wire] tensiometer,振弦式张力计
vibrating wire [resonant wire] tension transducer,振弦式张力传感器
vibrating wire [resonant wire] torque measuring instrument,振弦式转矩测量仪
vibrating wire [resonant wire] torque transducer,振弦式转矩传感器
vibrating wire transducer,振弦式(压力)传感器
vibration,振动
vibration amplitude,振幅
vibration analyzer,振动分析仪
vibration controller,振动控制仪
vibration cylinder barometer,振筒式气压表
vibration cylinder pressure transducer,振筒式气压传感器
vibration error,振动误差
vibration galvanometer,振动检流计
vibration generator,振动台;振动发生器
vibration isolation,隔振
vibration isolator,隔振器
vibration measurement by absolute method,绝对测振法
vibration measurement by mechanical method,机械测振法
vibration measurement by relative method,相对测振法
vibration monitor,振动监视器
vibration pick-up,振动传感器
vibration severity,振动烈度
vibration standard exciter,标准振动台
vibration test,振动试验
vibration transducer [sensor],振动传感器
vibrational severity,振动严酷度
vibrator,振动器
vibrator galvanometer,振动检流计
vibrometer,振动计
Vickers hardness number,维氏硬度值
Vickers hardness penetrator,维氏硬度压头
Vickers hardness tester,维氏硬度计
videometer,视程仪
virtual image,虚象
virtual image mass spectrometer,虚象质谱计
virtual memory,虚拟存储
viscometer,粘度计
viscosity,粘度
viscosity balance,粘度天平
viscosity transducer [sensor],粘度传感器
visibility,能见度
visibility marker,能见度目标物
visibility meter,能见度仪
visibility object,能见度目标物
visible function,视见函数
visible light transducer [sensor],可见光传感器
visible magnetic particle,非荧光磁粉
visible radiation,可见光辐射
visible spectral remote sensing,可见光遥感
visual axis,视轴
visual range,视程
visual range meter,视距测定仪
voltage amplifier,电压放大器
voltage center,电压中心
voltage circuit,电压电路
voltage constant,电压常数
voltage controlled gate (VCG)module,电压控制门组件
voltage-dependent resistor,电压敏电阻器
voltage divider,分压器
voltage divider with auxiliary branch circuit,具有辅助支路的分压箱
voltage error,电压比值差
voltage matching transformer,电压匹配互感器
voltage ratio,电压比
voltage ratio of a capaitor divider,电容器式分压器的电压比
voltage-regulation coefficient,稳压系数
voltage-second calibrator,伏秒定标器
voltage sensitivity,电压灵敏度
voltage stabilized thermistor,稳压热敏电阻器
voltage transducer [sensor],电压传感器
voltage transformer,电压互感器
voltammetry,伏安法
volt-ammpere meter,视在功率表
volt-ampere-hour metr,视在功率电度表;伏安时计
voltmeter,电压表
volume conductive humidity transducer [sensor],体电导式湿度传感器
volume flow,体积流量总量
volume flow-rate,体积流量
volume of the chamber,试验箱容积
volume thermodilatometry,体膨胀法
volume viscosity,体积粘度
volumetric chromatography,体积色谱法
volumetric flowmeter,容积式流量计
volumetric method,容积法
volumetric water meter,容积式水表
vortex flow transducer [sensor],涡街流量传感器
vortex flowmeter,旋涡流量计
vortex precession flowmeter,旋涡进动流量计
vortex shedding flow transducer,涡街流量传感器
vortex-shedding flowmeter,涡街流量计
