主题:【求助】weighted linear regression翻译
浏览0 回复6 电梯直达
sunrain001
Where three or more levels are utilised, an appropriate calibration
function may be calculated and used between the lowest and highest calibrated levels. The calibration curve (which may or may not appear to be linear) should, in general, not be forced through the origin. The fit of the calibration function must be plotted and inspected visually and/or by calculation of the residuals,
avoiding reliance on correlation coefficients, to ensure that the fit is satisfactory in the region relevant to the residues detected. If individual residuals deviate by more than ±20% (±10% in cases where the MRL is approached or exceeded) from the calibration curve in the relevant region, an alternative calibration function must be used. In general, the use of weighted linear regression is
recommended, compared to linear regression.
请教,最后一句的linear regression 和weighted linear regression怎么理解?
我在故我思
原文由 sunrain001 发表:最后一句的linear regression 和weighted linear regression怎么理解?
linear regression: 直线回归、线性回归
weighted linear regression: 加权直线回归
该帖子作者被版主 ruojun2积分, 2经验,加分理由:鼓励应助
happyjyl
楼主只要以“weighted linear regression”为关键词(注意打双引号)在google上搜索一下简体中文网页就能看到结果了。
sunrain001
深海的海豚
原文由 happyjyl 发表:
请教happy一下为什么要打双引号呢? 谢谢!
sun-quansheng
何当奇
原文由 lqqer 发表:
原文由 happyjyl 发表:
打双引号的话,搜索将按照词组来进行
qiuhan2010
线性回归和加权线性回归
该帖子作者被版主 redanqi1积分, 2经验,加分理由:鼓励新手应助
