原文由 雨木霖(mickeylin) 发表:
色谱柱固定液型号:SE.30
色谱柱详细参数:50*0.53*1um
使用范围:全部分析比如空气、水中的苯系物、TVOC、甲醇啥的
色谱柱固定液型号:RTX-1
色谱柱详细参数:30m*0.32*0.25um
使用范围:就偶尔用用,做苯系物。
色谱柱固定液型号:FFAP10%填充柱
色谱柱详细参数:2M*3mm,不锈钢
使用范围:貌似放在箱子里一直没用过
色谱柱固定液型号:GDX-502填充柱
色谱柱详细参数:2M*3MM,不锈钢
使用范围:也是从没用过,放在箱子里
色谱柱固定液型号:2.5%DNP
色谱柱详细参数:3M*3MM,不锈钢
使用范围:还是一直放在箱子里,没用过
色谱柱固定液型号:硅烷化玻璃微球
色谱柱详细参数:3M*3MM,玻璃填充柱
使用范围:非甲烷总统用的空柱。但是和GDX-502一样,因为我们对气相改装非甲烷总烃没有成功,所有也没用
没有谱图,只有照片。因为两根毛细柱都在仪器里,照片只上了填充柱的
Phase | Composition | max. Temperature [°C] * | Polarity |
OPTIMA® 1 | dimethylpolysiloxane | 340 / 360 | lowest |
OPTIMA® 1 MS | dimethylpolysiloxane with low bleeding | 340 / 360 | |
OPTIMA® 1 MS Accent | dimethylpolysiloxane with ultra-low bleeding | 340 / 360 | |
OPTIMA® 5 | 5 % phenyl – 95 % methylpolysiloxane | 340 / 360 | |
OPTIMA® 5 MS | 5 % diphenyl – 95 % dimethylpolysiloxane with low bleeding | 340 / 360 | |
OPTIMA® 5 MS Accent | silarylene phase with ultra-low bleeding: polarity similar to 5 % diphenyl – 95 % dimethylpolysiloxane | 340 / 360 | |
OPTIMA® 5 HT | cross-linked silarylene phase: polarity index according to 5 % phenyl – 95 % methylpolysiloxane | 380 / 400 | |
OPTIMA® XLB | silarylene phase with ultra-low bleeding: optimized silarylene content | 340 / 360 | |
OPTIMA® δ-3 | autoselective polarity between OPTIMA® 5 and OPTIMA® 1701 | 340 / 360 | |
OPTIMA® δ-6 | autoselective polarity between OPTIMA® 17 and OPTIMA® 210 | 340 / 360 | |
OPTIMA® 1301 | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane | 300 / 320 | |
OPTIMA® 624 | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane | 280 / 300 | |
OPTIMA® 624 LB | 6 % cyanopropylphenyl – 94 % dimethylpolysiloxane, low bleed | 280 / 300 | |
OPTIMA® 1701 | 14 % cyanopropylphenyl – 86 % dimethylpolysiloxane | 300 / 320 | |
OPTIMA® 35 MS | silarylene phase with very low bleeding: polarity similar to 35 % diphenyl – 65 % dimethylpolysiloxane | 360 / 370 | |
OPTIMA® 17 | phenylmethylpolysiloxane (50 % phenyl) | 300 / 320 | |
OPTIMA® 17 MS | silarylene phase with very low bleeding: polarity similar to 50 % diphenyl – 50 % dimethylpolysiloxane | 340 / 360 | |
OPTIMA® 210 | trifluoropropylmethylpolysiloxane (50 % trifluoropropyl) | 260 / 280 | |
OPTIMA® 225 | 50 % cyanopropylmethyl – 50 % phenylmethylpolysiloxane | 260 / 280 | |
OPTIMA® 240 | 33 % cyanopropylmethyl – 67 % dimethylpolysiloxane | 260 / 280 | |
OPTIMA® WAX | polyethylene glycol 20000 dalton | 240 / 250 | |
OPTIMA® WAXplus | polyethylene glycol with optimized crosslinking | 260 / 270 | |
OPTIMA® FFAP | polyethylene glycol-2-nitroterephthalate | 250 / 260 | highest |
