主题:【求助】Instrument detection limit for ICP (数据)
浏览0 回复7 电梯直达
liwutian
Al167.0Al308.2Al396.1As189.0Ba233.5Ba455.4Ca317.9Ca422.6Cd228.8
标准偏差S0.0003070.000810.0003790.0013760.0001760.0001560.0034840.003310.000103
0.0009640.0025430.001190.0043210.0005530.000490.010940.0103930.000323
ug/L0.963982.54341.190064.320640.552640.4898410.9397610.39340.32342
Co228.6Cr283.5Cu324.7Fe238.2Fe259.9Hg184.9K766.4k769.8Mg279.5
标准偏差S0.0001450.0001950.0001220.0001670.000158 0.0014340.0013990.0003
0.0004550.0006120.0003830.0005240.00049600.0045030.0043930.000942
ug/L0.45530.61230.383080.524380.4961204.502764.392860.942
Mg285.2Mn257.6Mo202.0Ni221.6Pb220.3Sb206.8Se196.0Sn189.9Ti334.9
标准偏差S0.0003130.0001520.0002980.0001610.0006860.0010130.0019220.0005170.000122
0.0009830.0004770.0009360.0005060.0021540.0031810.0060350.0016230.000383
ug/L0.982820.477280.935720.505542.154043.180826.035081.623380.38308
Zn206.2Zn213.8Zr339.1
标准偏差S0.0016140.0015450.000126
0.0050680.0048510.000396
ug/L5.067964.85130.39564
您可能想找: ICP-AES/ICP-OES 询底价
lilongfei14
是空白的数据吗?有点乱
2011/8/16 17:28:26 Last edit by lilongfei14
dahua1981
秋月芙蓉
sunmei
liwutian
不好意思,我这里解释一下,上面的数据格式是 元素 所选谱线 ,下面数据是按ug/L的单位算的,就是11次纯水的该元素三倍标准偏差。但是我和网上的常用元素的ICP仪器检出限表比较了一下,发现好多元素在对应的谱线下数据是常用数据的十分之一左右,我觉得这不是很正常。各位高手看看是不是我们的仪器检出限做法有问题?对了我们用的是热电的ICP6300
lilongfei14
原文由 liwutian(liwutian) 发表:
常用元素检出限给的值一般比实际值大
popo
你的积分条件是多少?
10S么?还是短波15S,长波10S?
