主题:【分享】我的一封撤稿信(含主编回复)
浏览0 回复7 电梯直达
gbluo324
由于稿子还在外审,凡涉及期刊名称及人名等均以XXX代替。不推荐大家学习,仅当阅读材料而已!
撤稿毕竟不是什么好的事情,投稿前最好考虑清楚。
我的去信:
Dear Prof. XXX,
I am writing to inform you that I have to withdraw the manuscript entitled "XXX"  for further  consideration for publication in your journal, due to some inaccuracies. I apologize for any inconvenience caused by the withdraw of this article.
Once again, thank you very much for your consideration and time.
With kind regards,
Yours sincerely,
XXX
主编回信:
Dear XXX,
Your submission has been removed.
Regards.
XXX, editor
稿件移除的邮件:
Ms. Ref. No.:
Title: XXX
Dear Mr. XXX,
I am sorry to have to inform you that XXX is unable to publish the paper that you submitted entitled "XXX" for the following reason(s):
The manuscript has been removed from the Elsevier Editorial System.
Yours sincerely
XXX
Editor
dahua1981
chemistryren
翠湖园
abcdefghijkl123
谁折腾
委员长
估计是投到另外一个更高级的期刊被接收了,两者选一,这家成为了备胎。以上纯属虚构,如有雷同,不胜荣幸!
gbluo324
正如楼上所说的那样,这篇稿子相隔两天分别投了2家杂志,都是某国的,为避免审稿人发现,所以及时撤了其中一家。当时以为很快就有审稿意见,结果撤稿的那家一个星期过去还没有分配编号呢。
