主题:【讨论】How do you do a troubleshooting the problem?(8 Sept)
浏览0 回复18 电梯直达
symmacros
If there are some trouble with instruments or equipments in your lab or your managing area, how do you do a troubleshooting the problem? Do you repair by yourself or ask customer service engineer to help?
该帖子作者被版主 myreebok10积分, 2经验,加分理由:sign up
abcdefghijkl123
We  ask customer service engineer to help.
该帖子作者被版主 myreebok1积分, 2经验,加分理由:sign up
hxf119
该帖子作者被版主 smileqing1积分, 2经验,加分理由:sign
watertime
Usually, ask customer service engineer to help.
上海卓技
If I can sovle the problem by myself, I will do it by myself
If I can't I will ask customer service engineer
cuishuanghua
Usually, call first consulting after engineers, is not really good will, door to door service service!
harriet
we usually check and repair it by ourself .if we can not resolve the problem and will call the instrument supplier.
mengzhaocheng
天晴了
I don't have the experience of using analytical equipment. But when my computer, mobilephone or other things have problems, I usually search in the internet to find the possible reason. Then ask the customer service staff or maintenance people to solve the problem.
zxl317189452
小M
First, we try to solve the problem ourselves.If we can't solve it, then we will call service engineer.
2011/9/8 9:05:20 Last edit by mitchell_dyzy
