主题:【分享】食品中野燕枯残留量的测定
雾非雾
附件请参考。
rzxjz
A simple analytical procedure is described for the quantitative determination of low levels of difenzoquat in water. It involves trace enrichment of difenzoquat with a C18 SEP-PAK reverse phase cartridge, followed by high performance liquid chromatographic determination with ultraviolet detection at 255 nm. The recoveries from the laboratory spiked samples are above 88%. The practical detection limit by this method is 2 ppb.
附件为薄层分析的方法。
