转自:http://www.jx.cn/bussines/jszlenglish.asp
3-Jaws indexing spacers 三爪、分割工具头
A.T.C.system 加工中心机刀库
Aluminum continuous melting & holding furnaces 连续溶解保温炉
Balancing equipment 平衡设备
Bayonet 卡口
Bearing fittings 轴承配件
Bearing processing equipment 轴承加工机
Bearings 轴承
Belt drive 带传动
Bending machines 弯曲机
Blades 刀片
Blades,saw 锯片
Bolts,screws & nuts 螺栓,螺帽及螺丝
Boring heads 搪孔头
Boring machines 镗床
Cable making tools 造线机
Casting,aluminium 铸铝
Casting,copper 铸铜
Casting,gray iron 铸灰口铁
Casting,malleable iron 可锻铸铁
Casting,other 其他铸造
Casting,steel 铸钢
Chain drive 链传动
Chain making tools 造链机
Chamfer machines 倒角机
Chucks 夹盘
Clamping/holding systems 夹具/支持系统
CNC bending presses 电脑数控弯折机
CNC boring machines 电脑数控镗床
CNC drilling machines 电脑数控钻床
CNC EDM wire-cutting machines 电脑数控电火花线切削机
CNC electric discharge machines 电脑数控电火花机
CNC engraving machines 电脑数控雕刻机
CNC grinding machines 电脑数控磨床
CNC lathes 电脑数控车床
CNC machine tool fittings 电脑数控机床配件
CNC milling machines 电脑数控铣床
CNC shearing machines 电脑数控剪切机
CNC toolings CNC刀杆
CNC wire-cutting machines 电脑数控线切削机
Conveying chains 输送链
Coolers 冷却机
Coupling 联轴器
Crimping tools 卷边工具
Cutters 刀具
Cutting-off machines 切断机
Diamond cutters 钻石刀具
Dicing saws 晶圆切割机
Die casting dies 压铸冲模
Die casting machines 压铸机
Dies-progressive 连续冲模
Disposable toolholder bits 舍弃式刀头
Drawing machines 拔丝机
Drilling machines 钻床
Drilling machines bench 钻床工作台
Drilling machines,high-speed 高速钻床
Drilling machines,multi-spindle 多轴钻床
Drilling machines,radial 摇臂钻床
Drilling machines,vertical 立式钻床
drills 钻头
Electric discharge machines(EDM) 电火花机
Electric power tools 电动刀具
Engraving machines 雕刻机
Engraving machines,laser 激光雕刻机
Etching machines 蚀刻机
Finishing machines 修整机
Fixture 夹具
Forging dies 锻模
Forging,aluminium 锻铝
Forging,cold 冷锻
Forging,copper 铜锻
Forging,other 其他锻造
Forging,steel 钢锻
Foundry equipment 铸造设备
Gear cutting machines 齿轮切削机
Gears 齿轮
Gravity casting machines 重力铸造机
Grinder bench 磨床工作台
Grinders,thread 螺纹磨床
Grinders,tools & cutters 工具磨床
Grinders,ultrasonic 超声波打磨机
Grinding machines 磨床
Grinding machines,centerless 无心磨床
Grinding machines,cylindrical 外圆磨床
Grinding machines,universal 万能磨床
Grinding tools 磨削工具
Grinding wheels 磨轮
Hand tools 手工具
Hard/soft and free expansion sheet making plant 硬(软)板(片)材及自由发泡板机组
Heat preserving furnaces 保温炉
Heating treatment funaces 熔热处理炉
Honing machines 搪磨机
Hydraulic components 液压元件
Hydraulic power tools 液压工具
Hydraulic power units 液压动力元件
Hydraulic rotary cylinders 液压回转缸
Jigs 钻模
Lapping machines 精研机
Lapping machines,centerless 无心精研机
Laser cutting 激光切割
Laser cutting for SMT stensil 激光钢板切割机
Lathe bench 车床工作台
Lathes,automatic 自动车床
Lathes,heavy-duty 重型车床
Lathes,high-speed 高速车床
Lathes,turret 六角车床
Lathes,vertical 立式车床
Lubricants 润滑液
Lubrication Systems 润滑系统
Lubricators 注油机
Machining centers,general 通用加工中心
Machining centers,horizontal 卧式加工中心
Machining centers,horizontal & vertical 卧式及立式加工中心
Machining centers,vertical 立式加工中心
Machining centers,vertical double-column type 立式双柱加工中心
Magnetic tools 磁性工具
Manifolds 集合管
Milling heads 铣头
Milling machines 铣床
Milling machines,bed type 床身式铣床
Milling machines,duplicating 仿形铣床
Milling machines,horizontal 卧式铣床
Milling machines,turret vertical 六角立式铣床
Milling machines,universal 万能铣床
Milling machines,vertical 立式铣床
Milling machines,vertical & horizontal 立式及卧式铣床
Mold & die components 模具单元
Mold changing systems 换模系统
Mold core 模芯
Mold heaters/chillers 模具加热器/冷却器
Mold polishing/texturing 模具打磨/磨纹
Mold repair 模具维修
Molds 模具
Nail making machines 造钉机
Oil coolers 油冷却器
Overflow cutting machines for aluminium wheels 铝轮冒口切断机
P type PVC waterproof rolled sheet making plant P型PVC高分子防水
PCB fine piecing systems 印刷电器板油压冲孔脱料系统
Pipe & tube making machines 管筒制造机
Planing machines 刨床
Planing machines vertical 立式刨床
Pneumatic hydraulic clamps 气油压虎钳
Pneumatic power tools 气动工具
Powder metallurgic forming machines 粉末冶金成型机
Presses,cold forging 冷锻冲压机
presses,crank 曲柄压力机
Presses,eccentric 离心压力机
Presses,forging 锻压机
Presses,hydraulic 液压冲床
Presses,knuckle joint 肘杆式压力机
Presses,pneumatic 气动冲床
Presses,servo 伺服冲床
Presses,transfer 自动压力机
Pressing dies 压模
Punch formers 冲子研磨器
Quick die change systems 速换模系统
Quick mold change systems 快速换模系统
Reverberatory furnaces 反射炉
Rollers 滚筒
Rolling machines 辗压机
Rotary tables 转台
Sawing machines 锯床
Sawing machines,band 带锯床
Saws,band 带锯
Saws,hack 弓锯
Saws,horizontal band 卧式带锯
Saws,vertical band 立式带锯
shafts 轴
Shapers 牛头刨床
Shearing machines 剪切机
Sheet metal forming machines 金属板成型机
Sheet metal working machines 金属板加工机
Slotting machines 插床
spindles 主轴
Stamping parts 冲压机
Straightening machines 矫直机
Switches & buttons 开关及按钮
Tapping machines 攻螺丝机
Transmitted chains 传动链
Tube bending machines 弯管机
Vertical hydraulic broaching machine 立式油压拉床
Vises 虎钳
Vises,tool-maker 精密平口钳
Wheel dressers 砂轮修整器
Woven-Cutting machines 织麦激光切割机
Wrenches 扳手
