The term “dry place” denotes a place that does not exceed 40% average relative humidity at Controlled Room Temperature or the equivalent water vapor pressure at other temperatures. 美国药典:干燥处指在控制的室温下平均相对湿度不超过40%,或者在其他温度下与40%相当的水蒸气压力。
原文由 Lynndi(v2702993) 发表: The term “dry place” denotes a place that does not exceed 40% average relative humidity at Controlled Room Temperature or the equivalent water vapor pressure at other temperatures. 美国药典:干燥处指在控制的室温下平均相对湿度不超过40%,或者在其他温度下与40%相当的水蒸气压力。
