For the detector design ,MEMS surface micromachining techniques were incorporated toFabricate a simple micro polysilicon air-bridge heater filament with integrated polysilicon electrodes. 这样翻译对吗? 有关这个检测器的设计,MEMS微机加工表面是一个纯微多晶硅空运线加热丝插入到多晶硅电极上。
再请教这段如何翻译? Fabrication of the device consisted of three mask levels . Fist a LPCVD Si3N4 film was deposited to create an Insolating barrier from the silicon substrate .Then 3μm of PECVD oxide was deposited And patterned. This layer is used as the sacrificial layer. Two microns of LPCVD polysilicon was then deposited and doped using N-type spin-on-glass. Aluminum was deposited on top of thepolysilicon and patterned with the heater and electrode structures. The aluminum was used as ahard mask to etch the polysilicon in RIE plasma system . The remaining aluminum was then pattern and etch to from contacts on the polysilicon heaters and electrodes. Finally the structures were released in a 49%HF etch. Because the heaters were 3mm long, they often stuck to the surface after release .This was due to capillary forces from the rinse after the release . To alleviate this problem ,a DI water/ IPA/ DI wafer / IPA rinse was incorporated followed by a 200℃ bake on a hot plate to suspend the structures.
