主题:【求助】ICPMS翻译 十一
浏览0 回复2 电梯直达
无机麦地
The presence or not of a shield around the torch, which is used to mitigate a secondary discharge in the interface of instruments that do not have a load coil configuration that minimizes the potential of the ICP versus the interface, can also affect the level of nonspectroscopic interferences。
求两个that的关系,看着句子结构就很复杂
您可能想找: ICP-MS电感耦合等离子体质谱 询底价
影子
第二个that后面的话是解释load coil configuration作用的吧?
无机麦地
谢谢,看了不少于二十遍了。即使是搞清楚了每一次单词的意思,这么复杂的结构太伤我脑了。
姑且看做是解释前面一个词吧
