主题:【讨论】关于OptoTemp 2000产品及其应用的潜力问题
浏览0 回复51 电梯直达
容百川
在某网友帮助下,俺找到了海洋光纤测温仪表:OptoTemp 2000 !
我昨天扫视了一遍,初看还以为是近距离的,后来看看,好像是光纤的,那就可能远距离测温度了。
不知道应用到哪些地方了,望海洋提点一下!
dahua1981
dahua1981
Up to 950 ºC - Immune to EMI and Microwave
The OptoTemp 2000 was designed for reliable operation in the harshest chemical and electrical environments. This fiber optic thermometer is unaffected by microwave/RF radiation and plasma and can measure temperatures up to 950 ºC.
The OptoTemp 2000 features patented technology for a monolithic single-crystal temperature probe that eliminates the need for unreliable mechanical coupling. It measures temperature using the information derived from fluorescence decay.
Benefits
Immune to EMI, RF and microwave
Operates up to 950 ºC
Precise and reliable
Inert probe
Applications
Microwave/RF heating
Chemical processing
Molten metal measurements
Plasma processing
Semiconductor processing
OptoTemp 2000 Controller Specifications
Channels: Up to 4
Temperature range: 10 ºC to 950 ºC
Response time: 250 ms
Precision: +/- 1.0 ºC RMS over 8 samples
Accuracy: +/- 2.0 ºC
Power requirement: 90-260 VAC, 50-60 Hz
Power consumption: 5W @ 7.5 VDC
Output port: RS-232
Display: Back lighted LED
OptoTemp 2000 Probe Specifications
  FLEX SUPER ULTRA
Temperature range: 10 ºC to 150 ºC 10 ºC to 400 ºC 10 ºC to 950 ºC
Connector type: ST ST SMA
Overall diameter: 2 mm 3 mm 3 cm*
Active probe length: 15 cm** 15 cm** 15 cm**
Protective sheath material PEEK Ceramic Ceramic
Item Code: OPTOTEMP-2000-FLEX OPTOTEMP-2000-SUPER OPTOTEMP-200-Ultra
Your Price: $2050 $2350 $2750
* A low thermal mass version with exposed 0.2 mm tip is also available
** Longer or shorter length available on custom probes
yuduoling
原文由 容百川(jjwws) 发表:
是新的仪表吗?
yuduoling
原文由 dahua1981(dahua1981) 发表:
百度了一下确实相关资料很少
是不是因为产品新,所以相关资料少?
savedown
savedown
容百川
原文由 yuduoling(yuduoling) 发表:
原文由 容百川(jjwws) 发表:
是新的仪表吗?
新不新,俺就不知道了。不过有这类产品,挺好
容百川
百度了一下确实相关资料很少
是不是因为产品新,所以相关资料少?
我也没怎么找到。可能是比较新。
容百川
Benefits
Inert probe
Applications
Chemical processing
Plasma processing
Channels: Up to 4
Output port: RS-232
  FLEX SUPER ULTRA
翻译一下更好!不过这上面提到的光纤探头(=光纤温度传感器器吧?)长度具体没说
容百川
原文由 savedown(savedown) 发表:
这一款产品好像国内都没有用户。
国外的也行啊,说不定更好
