原文由 dahua1981(dahua1981) 发表:原文由 容百川(jjwws) 发表:原文由 dahua1981(dahua1981) 发表:原文由 容百川(jjwws) 发表:原文由 yuduoling(yuduoling) 发表:原文由 容百川(jjwws) 发表:原文由 dahua1981(dahua1981) 发表:原文由 rexindhf(rexindhf) 发表:
红外热像仪,海洋目前没有。不过这个Opto Temp 是光纤荧光传感,
长度可以加长,几十米,上百米都没问题。不过光纤长度等要定制了
上百米也不好操作啊
有啥问题呢?
不好维护?
光纤距离长了很难维护吗?
是不是安装不方便啊?
我感觉主要是使用不方便吧
光纤接上之后,不是不会经常动得吗,还有哪些需要操作的地方?
如果不动的话这么长操作起来也费劲吧
原文由 happyalife(happyalife) 发表:原文由 dahua1981(dahua1981) 发表:
Up to 950 C - Immune to EMI and Microwave
The OptoTemp 2000 was designed for reliable operation in the harshest chemical and electrical environments. This fiber optic thermometer is unaffected by microwave/RF radiation and plasma and can measure temperatures up to 950 C.
The OptoTemp 2000 features patented technology for a monolithic single-crystal temperature probe that eliminates the need for unreliable mechanical coupling. It measures temperature using the information derived from fluorescence decay.
Benefits
Immune to EMI, RF and microwave
Operates up to 950 C
Precise and reliable
Inert probe
Applications
Microwave/RF heating
Chemical processing
Molten metal measurements
Plasma processing
Semiconductor processing
OptoTemp 2000 Controller Specifications
Channels: Up to 4
Temperature range: 10 C to 950 C
Response time: 250 ms
Precision: +/- 1.0 C RMS over 8 samples
Accuracy: +/- 2.0 C
Power requirement: 90-260 VAC, 50-60 Hz
Power consumption: 5W @ 7.5 VDC
Output port: RS-232
Display: Back lighted LED
OptoTemp 2000 Probe Specifications
FLEX SUPER ULTRA
Temperature range: 10 C to 150 C 10 C to 400 C 10 C to 950 C
Connector type: ST ST SMA
Overall diameter: 2 mm 3 mm 3 cm*
Active probe length: 15 cm** 15 cm** 15 cm**
Protective sheath material PEEK Ceramic Ceramic
Item Code: OPTOTEMP-2000-FLEX OPTOTEMP-2000-SUPER OPTOTEMP-200-Ultra
Your Price: $2050 $2350 $2750
* A low thermal mass version with exposed 0.2 mm tip is also available
** Longer or shorter length available on custom probes
看不懂啊,是在线的么,根据实际温度变化的仪器的显示也随之变化?
