【作者】 翁雪萍; 李惠敏;
【Author】 WENG Xueping, LI Huimin(Huizhou Institute for Drug Control, Huizhou 5 16008, Guangdong )
【摘要】 目的完善藿香正气胶囊的质量标准。方法增加薄层色谱法对方中白芷、广藿香、陈皮、白术的鉴别,采用高效
液相色谱法测定方中厚朴所含厚朴酚与和厚朴酚的含量,使用DiamonsilC18柱,甲醇-乙腈-水(20∶15∶9)为流动相,测定波长294nm。结果定性鉴别方法专属性强;厚朴酚线性范围为16.144~80.72μg/mL(r=0.9998),和厚朴酚线性范围为20.48~102.40μg/mL(r=0.9997),平均回收率分别为97.07%和97.89%,RSD分别为1.17%和1.06%(n=5)。结论该方法稳定、准确,可用于该制剂的质量标准。 更多还原
【Abstract】 Objective To establish a method for the quality control of Huox ia ng Zhengqi Capsules(HZC). Methods Radix Angelicae Dahuricae, Herba Pogostemo nis, Pericarpium Citri Reticulatae and Rhizoma Atractylodis Macrocephalae in HZ C were identified by TLC. The content of magnolol and honokiol were determined b y HPLC. The chromatographic conditions were: Diamonsil C18 (250 mm× 4.6 mm, 5 μ m) column, mobile phase being methanol- acetonitrile- water (20 ∶ 15 ∶ 9 ), and the detection wavelength at 294 nm.... 更多还原
【关键词】 藿香正气胶囊; 薄层色谱法; 厚朴酚; 和厚朴酚; 高效
液相色谱法; 含量测定;
【Key words】 Huoxiang Zhengqi Capsules; TLC; Magnolol; Honokiol; HPLC; Content derermiantion;
