ISQ1300-230LT | ISQ EI Only with Vacuum Interlock, extended capacity turbomolecular pump, computer, 1300 gc 230V | 1 | ||
TRACE1300气相色谱仪主机 1台 | ||||
含气质接口 1个 | ||||
质谱仪一台 | ||||
>300L/s分子涡轮泵 | ||||
2个EI源、真空锁定装置、电脑、控制软件 | ||||
19050720 | TRACE 1300/1310 Start-up kit | |||
TRACE 1300/1310启动工具包 | ||||
120383-0001 | NIST 11 MS Library for Xcalibur | |||
NIST11 谱库 | ||||
自动进样器 | ||||
25117580 | AI 1310 for TRACE 1300 Series gc (for stand alone; ISQ and ITQ configurations) | 1 | ||
8位自动进样器 | ||||
检测器 | ||||
19070001 | Instant Connect FID module FID(氢火焰离子化检测器) | 1 | ||
19070040 | Instant Connect TCD module TCD(热导检测器) | 1 | ||
常用备品备件及耗材 | ||||
453A1295 | SSL Split Straight Liner, , Deactivated, 4mm ID x 6.3mm OD x 78.5mm Length | 1 | ||
去活化分流衬管,5根/包 | ||||
453A1345 | SSL Splitless Liner with Single Taper, Deactivated, 4mm ID x 6.3mm OD x 78.5mm Length | 1 | ||
去活化不分流衬管,5根/包 | ||||
290VA192 | Graphite Vespel Ferrule for 0.32mm Column | 1 | ||
0.32mm耐高温、低流失石墨垫 | ||||
290GA081 | Gold Base Seal, Single Column Installation 0.8mm Diameter | 1 | ||
镀金密封圈 | ||||
36520060 | 10L FN Syringe, 50mm Length, 23 Gauge, Cone, 1pk | 1 | ||
10L液体进样针(自动进样器) | ||||
60180-599 | 2mL Screw Vial, 9mm Cap, SIL/PTFE 100/pk | 1 | ||
2ml透明小瓶 | ||||
1R120404-1900 | DUAL FILAMENT ASSY ISQ | 1 | ||
ISQ灯丝 | ||||
A0301-15101 | OIL,VACUUM PUMP,1 LITER | 1 | ||
真空泵油, 1L | ||||
29033496 | Vespel Ferrule For Varian 0.1-0.25 Pk 10 | 1 | ||
传输线端石墨垫, 0.1-0.25mm, 10个 | ||||
1R76458-2016 | Graphite Vespel Ferrule for 0.25 mm Columns, pk 10 | 1 | ||
质谱端石墨垫, 0.25mm, 10个 | ||||
1R76256-0060 | NUT SGE 1/16”x1.2mm - Brass - pk of 5 | 1 | ||
传输线端螺帽, 5个 | ||||
260X142P | TRACE TR-WaxMS gc Column, 30m, 0.25mmID, 0.25洀 Film | 1 | ||
极性质谱柱 | ||||
260Q142P | TRACE TR-1701 gc Column, 30m, 0.25mmID, 0.25洀 Film | 1 | ||
农残分析柱 | ||||
HP电脑、打印机 | 1 | |||
氢气发生器300ml/min | 1 | |||
高纯氦气钢瓶(气、阀) | 1 | |||
空气发生器2000ml/min | 1 |
