别名:lambda-Cyhalothrin
化合物名称:Commodore
化合物名称 (CAS):3-[(Z)-2-chloro-3,3,3-trifluoroprop-1-enyl]-2,2-dimethy$$lcyclopropanecarboxylic acid [cyano-(3-phenoxyphenyl)methyl] ester
化合物名称 (IUPAC):[cyano-(3-phenoxyphenyl)methyl] 3-[(Z)-2-chloro-3,3,3-trifluoroprop-1-enyl]-2,2-dimethy$$lcyclopropane-1-carboxylate
结构式:
分子式:C23H19ClF3NO3
分子量:449.85007
手性中心数量:3
氢键受体数量:7
氢键给体数量:0
总电价:0
Log P(已计算):6.1
Log P-AA:
分离模式 | 标题 | 色谱柱 |
Gas Chromatography | Multipesticide Screen by MSD on ZB-5 | Zebron™ ZB-5, gc Cap. Column 30 m x 0.25 mm x 0.25 µm, Ea |
Reversed Phase Chromatography | iMethod: Screening >350 Pesticides from Food & Feed According to Regulation (EC) No. 396/2005 | Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea |
Reversed Phase Chromatography | iMethod™ Food - Screening of 535 Pesticides by QuEchERS and $$lc/MS/MS | Synergi™ 2.5 µm Fusion-RP 100 Å, $$lc Column 50 x 2 mm, Ea |
分离模式:Gas Chromatography,Reversed Phase Chromatography
化合物类别:Environmental / Health
化合物分类:Pesticide / Insecticide
药理作用:Anthelmintics,Insecticides
