【作者】 郝万红; 孙红梅;
【Author】 Hao Wanhong1,Sun Hongmei2 (1.Pharmaceutical Factory,Shandong Wanjie High Tech.Stock Co.,Ltd.,Zibo,Shand ong,China 255213;2.Wanjie Hospital of Zibo,Shandong Province,Zibo,Shandong,China 255213)
【机构】 山东万杰高科技股份有限公司制药厂; 山东淄博万杰医院 山东淄博255213; 山东淄博255213;
【摘要】 目的用高效
液相色谱法(HPLC法)测定去氧氟尿苷的含量及其有关物质。方法采用DiamonsilC18柱(250mm×4.6mm,5μm),流动相为乙腈-水(1∶1),检测波长为269nm,流速为0.8mL/min。结果去氧氟尿苷质量浓度在10.0~200.4μg/mL范围内与峰面积线性关系良好,r=0.9999(n=5),平均回收率为100.2%,RSD=0.14%。结论HPLC法简便、准确,专属性好,灵敏度高,可用于去氧氟尿苷含量及有关物质的测定。 更多还原
【Abstract】 Objective To establish HPLC method for determination of doxiflurid in e content and its related substances.Methods The column was Diamonsil-C18 colum n (250 mm×4.6 mm,5 μm).The mobile phase was acetonitrile-water (1 ∶1).The detection wavelength was 269 nm.The flow rate was 0.8 mL/min.Results There was a good linear relationship with the range of 10.0-200.0 μg/mL for determinati on of the doxifluridine’s content,r=0.999 9(n=5).The average recovery rate was 100.2%,RSD=0.14%.Conclusion The method i... 更多还原
【关键词】 去氧氟尿苷; 含量测定; 有关物质; 高效
液相色谱法;
【Key words】 doxifluridine; content determination; related substances; HPLC;
