152.1 高效液相色谱法测定跌打活络微乳中蛇床子素的含量
【作者】 王利胜; 占建坤; 周莉玲; 【Author】 WANG Li-sheng~1,ZHAN Jian-kun~2,ZHOU Li-ling~1(1.College of Traditional Chinese Materia Medica,Guangzhou University of TCM,Guangzhou 510405,China;2.Grade 2002 Undergraduate of Pharmaceutical Engineering,College of Traditional Chinese Materia Medica,Guangzhou University of TCM,Guangzhou 510405,China)【机构】 广州中医药大学中药学院; 广州中医药大学中药学院 广东广州510405; 2002级制药工程; 广东广州510405; 【摘要】 目的建立跌打活络微乳中蛇床子素含量的测定方法。方法采用高效液相色谱法,色谱柱:D iamonsil(钻石C18(5μm,250 mm×4.6 mm);流动相:甲醇-水(80∶20),检测波长:322 nm;流速:1 m l/m in。结果蛇床子素在0.042~0.336μg线性关系良好,r=0.999 7,平均回收率为100.91%,RSD为2.42%(n=6)。结论该法操作简便,结果准确,灵敏度高,重现性好,可用于该制剂的质量控制。 更多还原【Abstract】 ObjectiveTo establish the determination method for osthole in Dieda Huoluo Microemulsions.MethodsHPLC was used with DiamonsilC18 column(250 mm×4.6 mm,5 μm),detection wavelength at 322 nm,mobile phase: methanol-water(80∶20),flow rate: 1ml/min.ResultsOsthole has good linear relationship between 0.0420.336 μg,r=0.999 7,the recovery of osthole was 100.91% and RSD was 2.42%(n=6).ConclusionThe method is simple,sensitive and reliable to carry out to control the quality of this pr... 更多还原
【关键词】 跌打活络微乳; 高效
液相色谱法; 蛇床子素;
【Key words】 Dieda Huoluo Microemulsions; HPLC; Osthole;
【基金】 国家自然科学基金“中药经皮给药系统局部药动学研究”(No.30371783)
