原文由 烂橘子(v2698791) 发表:
原文由 chun870605(justforyou9) 发表:
楼主,我也是pe 5300dv,测玩具重金属的
雾化器压力是正常的。你的1PPm的Mn校准观测强度是多少?我的大概是8w到10w。1pm Mn标液开描光的话大概33w
还是你看看是不是雾化效果不好,要不做个钠锥看看
就是强度不高, 1ppm的锰在20w 以下, 仪器说明书 不是说10ppm 的锰 要在300w以上吗
那你的也Mn强度也不高哦,
另外钠锥是什么 ![]()
Sodium Bullet Test
To run the sodium bullet test:
1. For aqueous analyses, aspirate a 1000 mg/L solution of sodium. For organic
analyses, aspirate an appropriate organic blank.
2. Examine the plasma through the viewing window in the sample compartment
door.
A yellow-orange bullet (or green, in the case of organic compounds) should be
visible in the center of the discharge, and should extend from the base of the
discharge to about 2-3 mm above the top of the RF coil. If the bullet height is
unsatisfactory, adjust the nebulizer argon flow in the Method Editor or Plasma
Control windows.
If no bullet appears or the bullet is faint:
Check that your sample does contain sodium at the required concentration.
Check that sample is being pumped to the nebulizer. Make sure that the pump
lever is engaged and that the pump tubes are connected appropriately.
Check that the drain is being pumped properly. You should see a segmented
flow of bubbles through the tubing.
10个ppm的是300w,那我1个ppm的是30w,差不多了
钠锥,是看等离子体的位子吗?
形象化的清楚进样系统的情形,知道有没有堵
有没有堵看背压就可以了。
PE的,正常值应当是多少? 现在是126mpa,有时达到过140mpa,高了说明堵吗?
