原文由 pjs123 发表:
you can get what you want from the following :
I contacted an editor at Pollution Engineering Magazine (E-mail: KCanning@cahners.com) who refered me to a Ph.D. in Germany named Dr. Thomas Schmidt (E-mail: schmidt@mpi-muelheim.mpg.de), who explained that the N term is an abbreviation of norm or normal. He continued to explain that "Normal, in this connection, means a temperature of 0 degrees Celsius and a pressure of 1.013 bar, the conditions at which one mole of an ideal gas has a volume of 22.413837 liters." This definition makes sense to me in conjunction with a flue gas measurement. Ken Johnson, an administrator with the MadSci Network (E-mail: kayjay45@home.net) confirmed this explantion with an environmental scientist in Australia. By comparison, we routinely use ppm (parts per million)in the USA for this type of measurement.
I want to Thank You, for helping me learn something new in the world of Chemistry. I would also like to thank all of the scientists that helped me to define this unit of measurement for you.
