主题:【原创】利用ICSD软件查看,可见如下信息,请问,建立晶胞是哪个参数
liumeimei
利用ICSD软件查看,可见如下信息,请问,建立晶胞是哪个参数:
“Atom  #  OX  SITE      x          y          z          SOF      H
C    1  +2    4 a  -.042      -.042      -.042          1.        0
O    1  -2    4 a  0.067      0.067      0.067          1.        0    ”
还是用
C    1  +2    4 a  .29200      .29200      .29200        1.
O    1  -2    4 a  .18300      .18300      .18300        1.
ICSD原始数据:*data for  ICSD #26962
Coll Code  26962
Rec  Date  1986/09/24
Mod  Date  2007/08/01
Chem Name  Carbon Oxide - Lt
Structured  C O
Sum        C1 O1
ANX        AX
D(calc)    1.04
Title      Struktur und Leuchtfaehigkeit von festem Kohlenoxyd.
Author(s)  Vegard, L.
Reference  Zeitschrift fuer Physik
            (1930), 61, 185-190
            Phase Transition
            (1992), 38, 127-220
Unit Cell  5.63 5.63 5.63 90. 90. 90.
Vol        178.45
Z          4
Space Group P 21 3
SG Number  198
Cryst Sys  cubic
Pearson    cP8
Wyckoff    a2
Red Cell    P  5.63 5.63 5.63 90 90 90 178.454
Trans Red  1.000 0.000 0.000 / 0.000 1.000 0.000 / 0.000 0.000 1.000
Comments    Stable below 62 K (2nd ref., Tomaszewski), above 62 K
            P63/mmc
            AE: isolated C-O-molecules (C-O=1.06)
            Isopointal to Fe Si-type; SB: B21-type
            The structure has been assigned a PDF number (calculated
            powder diffraction data): 01-074-1229
            The structure has been assigned a PDF number (experimental
            powder diffraction data): 46-1039
            Standard deviation missing in cell constants
            Structure type prototype : CO
            Temperature in Kelvin: 20
            Structure type : CO
            X-ray diffraction (powder)
            No R value given in the paper.
            At least one temperature factor missing in the paper.
Std. Notes  Transformation Method: Tidy
            TRANS  1/4-y,1/4-x,1/4-z
Std. Cell  5.6300 5.6300 5.6300 90 90 90 178.45
Std. Vol.  178.45
Std. Z      4
Std. SG    P213
Std. Atom
*end for    ICSD #26962
December12
应该是一样的,选一套就行~~还有参数很简单啊,自己试试呗。。。
