Typically, the advanced experiments that research-grade Nicolet FT-IR sepctrometers perform can be classified into nine broadly defined experimental categories. These categories are based on different operation modes and demonstrated with sixteen representative applicaition examples. The nine experimental categories include:
1)Extened spectral range experiments (27000-15cm-1, i.e. from far-IR up to near ultra violet)
2)High resolution spectroscopy (better than 0.09cm-1 for gas phase measurements)
3)Single-channel rapid-scan kinetics (77 spectral/sec at 8cm-1 spetral data resolution)
4)Dual-channel polarization modulation spectroscopic experiments(IRRAS, VLD, and VCD, absorbance level on the order of 10-3 to 10-5)
5)Step-scan amplitude modulation (electroluminescence measurement)
6)Step-scan phase modulation (photoacoustic depth profiling)
7)Step-scan sample modulation (polymer streching, liquid crystal dynamics, and spectro-electrochemistry)
8)Step-scan time-resolved spectroscopy (ns chemical kenetics, polymer streching, liquid crystal dynamics and photoacoustic depth profiling)
9)Step-scan space-resolved spectroscopy (focal plane array detector-based IR imaging)
The potential for other modulation and TRS experiments is unlimited. Combined techniques from different categories may also be used, enabing experiments such as TRS-based PM-IRRAS, kinetic PM-IRRAS and so forth. The relationship between these typical experiments is summarized in Figure 1.10. In the following chapters ,these experiments will be addressed in more detail.
