主题:【第一期专业英语翻译之星产生了!——双子星】
浏览0 回复30 电梯直达
weiz
该帖子已被weiz设置为精华;
悬赏金额:100积分 状态: 已解决
环保先锋molybdenum
说明:
环保先锋网友首先提出译文,第一个吃螃蟹的人当然应当奖励,而且他的译文基本上是正确而通顺的。
molybdenum网友的译文首次纠正了之前翻译有误的地方,而且热心参加我们的活动,还对自己的译文进行了仔细的修改。
感谢所有参加此次活动的网友,尤其是piery2006网友,很犀利呀!
本次没有当选的各位网友不要灰心,我们还有很多次活动可以让你们大显身手。
因为是第一次活动,为了鼓励大家的积极性,所以选出了两个星星,以后的活动100个积分将由一位网友独享。
色谱的历史,虽然较长(约200单词),但难度并不大,欢迎大家抽出一些时间参加。
History of Chromatography
Chromatography -- what does it mean?
To write with colors -- literally translated from its Greek roots chroma and graphein , chromatography was first developed by the Russian botanist Mikhail Tswett in 1903 as he produced a colorful separation of plant pigments through a column of calcium carbonate. Chromatography has since developed into an invaluable laboratory tool for the separation and identification of compounds. Although color usually no longer plays a role in the process, the same principles of chromatography still apply.
Why use chromatography? The key here is separation. But what is the importance of separation in the lab?
Separation of chemical components is vital in any type of chemical analysis. When trying to identify an unknown substance, the sample must first be simplified as much as possible into its constituent compounds. The unknown can then be characterized by individual identification of its parts. This does not imply that the separated chemical components are recovered after the separation and analyzed. Usually, the analytes are irretrievable. Separated compounds are compared to known standards. As with most chemical exploration, it is important to have an idea of what compounds are being searched for in the first place.
推荐答案:无名回复于2006/09/04
抛砖引玉:翻译的不好请见谅,有些时候感觉用文字将自己的理解描述出来有些难。
色谱的历史
色谱-什么意思呢?
To write with colors -- literally translated from its Greek roots chroma and graphein, chromatography was first developed by the Russian botanist Mikhail Tswett in 1903 as he produced a colorful separation of plant pigments through a column of calcium carbonate. Chromatography has since developed into an invaluable laboratory tool for the separation and identification of compounds. Although color usually no longer plays a role in the process, the same principles of chromatography still apply.
字面由希腊文字色彩和谱图而来。色谱最早于1903年俄罗斯植物学家Mikhail Tswett以碳酸钙柱分离植物色素时发现。之后色谱发展成为实验室进行化合物分离和鉴别的不可替代的重要工具,尽管颜色已不再扮演判断的角色但色谱的基本原则依然应用。
为什么使用色谱呢?关键在于分离,但分离的重要性是什么呢?
在各种化学分析中,分离化合物至关重要。当试图鉴别未知物质的时候,首先需要将混合物尽量分离成单一物质。然后通过特定的鉴别确认单一成分特征。这一过程并不意味着经过分离和分析过程后单一化学成分发生改变。通常,这一过程不可逆变。然后将分离得到的化合物与已知标准物进行比较。大多的化学鉴别情况下,如何发现第一个化合物极为重要。
补充答案:
molybdenum回复于2006/09/13
这是英语竞赛,大家各显其能,若您不赞同前面的翻译,可以给出您的完整译文,也许能够当选“专业英语翻译之星”呦!
很是同意21楼的提议,偶也承认采用了一些他人的翻译。
感谢22楼的意见。其实单个单词的意思大家可能都知道,关键是怎么把它组织成流利通畅易懂的句子。再次整理了一下译文如下:
色谱的历史
色谱——是什么意思呢?从它的希腊词根'chroma'和'graphein',逐字翻译过来就是:用颜色来记录。色谱最先由俄罗斯植物学家Mikhail Tswett于1903年提出,当时他通过一根碳酸钙柱子使植物叶绿素产生了色带分离。之后,色谱发展成为实验室化合物分离和鉴定的无比宝贵的工具。尽管颜色在色谱分析过程中大抵不再发挥作用,但相同的色普原理依然在使用。
为什么使用色谱呢?此处的关键在于分离。那么,实验室内分离的重要性是什么呢?
在任何类型的化学分析中,化学组成的分离是至关重要的。当试图鉴别一种未知物时,首先必须将该样品尽可能的纯化为它的组分化合物。然后,该未知物才能被它的片段的特殊标识表征出来。但这并不意味着经过分离和分析后被分离的化学组分可以回收。通常情况下,被分析物是不可复原的。被分离的化合物被用来与已知的标准物进行对比。由于使用了大部分化学探测方法,因而知道哪一个是首要寻找的化合物非常重要。
wavelsb
无名
色谱的历史
色谱-什么意思呢?
weiz
nj_wjg_nj
尝试一下!不过声明在先,我已经看过楼上的帖了,翻的的确不错!根据个人认知,只是在个别地方作了修改。
色谱的历史
色谱——它是什么意思呢?
从字面讲该词源于希腊文字色彩和图谱,它最早于1903年由俄罗斯植物学家Mikhail Tswett提出。他是在通过碳酸钙柱分离植物色素时用于描写各种颜色的色素时使用该词的。之后色谱发展成为实验室进行化合物分离和鉴别的不可替代的重要工具,尽管颜色已不再扮演判断的角色但色谱的基本原则依然应用。
为什么使用色谱呢?关键在于分离,但实验中分离的重要性是什么呢?
在各种化学分析中,分离化学成分至关重要。当试图鉴别未知物质的时候,首先需要将试样尽可能的分离成单一物质。然后未知物质才可以通过单一物质的特征得到确认。但这并不意味着经过分离和分析过程后被分离的化学组分可以恢复。通常,这一过程不可逆变。然后将分离得到的化合物与已知标准物进行比较。大多的化学鉴别情况下,如何发现第一个化合物极为重要。
weiz
大意正确,但部分细节还需要推敲呦,希望后来者能使译文更为精确而通顺。
过客
我也来试试看,楼主到时可要公布一下正确的翻译哦!
色谱的历史
色谱--它是什么意思呢?
用该词的风格来说--从字面讲该词源于希腊的色度和图谱,它最早于1903年由俄罗斯植物学家Mikhail Tswett提出,他是在通过碳酸钙柱分离植物色素时用于描写各种颜色的色素时使用该词的。之后色谱发展成为实验室进行化合物分离和鉴别的不可替代的重要工具,尽管颜色已不再扮演判断的角色但色谱的基本原则依然应用。
为什么使用色谱呢?这里的关键在于分离,但实验室中分离的重要性是什么呢?
weiz
原文由 xfgong 发表:
我们这个竞赛没有标准答案的,因为翻译这种事仁者见仁,智者见智,只要准确而流畅的译出原文的意思即可,我们比的就是理解、精确和通顺。
以上诸位的翻译都很好,不过有些关键点的理解还有一些问题。
加油呀!
joe8
我也来试试看。理解水平有限,请楼主指点哦。
色谱的历史
色谱--它是什么意思呢?
    用该词的风格来描述——从字面意义上讲该词源于希腊文字的色度和图谱。它最早在1903年由俄罗斯植物学家Mikhail Tswett提出,他是在通过碳酸钙柱分离植物色素时用于描写各种颜色的色素时使用该词的。之后色谱便发展成为实验室里进行化合物分离和鉴别不可替代的重要工具。尽管色彩已不再扮演判断的角色,但色谱的基本原则却依然被应用。
    为何要使用色谱呢?关键是在分离,但在实验中分离的重要性又是什么呢?
    在各种类型的化学分析中,化学成分的分离至关重要。在人们想要鉴别未知物时,首先必须要尽可能地将样品分离成单一物质,然后通过特定的鉴别确认单一成分的特征。但这并不意味着经过分离和分析过程后被分离的化学组分可以恢复。通常,这一过程是不可逆变的。最后将分离得到的化合物与已知标准物进行比较。以此来确定未知物。就大多的化学鉴别而言,如何找出第一个化合物极为重要。
molybdenum
色谱的历史
色谱——什么意思呢?根据它的希腊词根'chroma'和'graphein',字面上翻译过来意思就是:用色彩来记录。色谱最早于1903年由俄罗斯植物学家Mikhail Tswett提出,当时他用碳酸钙柱子对植物色素按色彩进行了分离。之后,色谱发展成为实验室化合物分离和鉴定的不可替代的重要工具。尽管色彩在色谱分析过程中已不再发挥作用,但相同的原理依然在使用。
为什么使用色谱呢?此处的关键在于分离。那么,实验中分离的重要性是什么呢?
在各种化学分析中,化学成分的分离是至关重要的。当试图鉴别一种未知物质时,首先需要将试样尽可能的纯化为它的组分化合物。然后该未知化合物才能被它的特殊标识表征出来。但这并不意味着经过分离和分析过程后被分离的化学组分可以再生。通常情况下,被分析物是不可复原的。被分离的化合物被用来与已知的标准物进行对比。在众多的化学测试中,知道哪个是首要寻找的化合物是非常重要的。
Last edit by molybdenum
joe8
楼上翻译得不错,读起来比较顺口,理解起来也不难,真是厉害啊!
