安装英文windows时,系统提示:this version of microsoft scandisk will work only with ms-dos versions 5.5 and later.setup found a commressed volume or a disk-cache utility on your computer,quit setup and check your compressed volume with your disk compression software or remove the disk-cache utility,then run setup again.如何解决?谁能提供英文windows系统?急急急!!!!!!
