3. 国外标准
记录号: 20423
【标准号】:BS EN 14107-2003
【标准名称】:Fat and oil derivatives - Fatty acid methyl esters (FAME) - Determination ofphosphorous content by inductively coupled plasma (ICP) emission spectrometry
【标准其他名称】:脂肪和油的衍生物.脂肪酸甲基酯(FAME).用电感耦合等离子体(ICP)辐射光谱法测定磷含量
【标准年】:2003
【页码】:12P;A4
【总页数】:12
【标准分类号】:中国标准分类法X14; 国际标准分类法67.200.10
【主题词】:测定; 含量; 油的衍生物; 动物油; 脂肪酸甲酯; 磷; 化学分析和试验; 试验; 定义;甲酯; 磷含量; 植物油; 液体; 脂肪酸; 油; ICP; 光谱测定法; 实验室间试验; 脂肪; 食品; 含量测定; 分析;Analysis; Animal oils; Chemical analysis and testing; Content; Definition; Definitions; Derivativeof oil; Determination; Determination of content; FAME; Fats; Fatty acid methylesters; Fatty acids;Food products; ICP; Inter-laboratory tests; Liquid; Methyl esters; Oils; Phosphorus; Phosphoruscontent; Spectrometry; Testing; Vegetable oils
4. 国外标准
记录号: 48333
【标准号】:DIN 50451-3-2003
【标准名称】:Testing of materials for semiconductor technology - Determination of traces ofelements in liquids - Part 3: Aluminium (Al), cobalt (Co), copper (Cu), sodium (Na), nickel (Ni) andzinc (Zn) in nitric acid by
ICP-MS【标准其他名称】:半导体工艺用材料测试.液体中痕量元素测定.第3部分:用
电感耦合等离子体质谱法测定硝酸中铝(AL)、钴(Co)、铜(Cu)、钠(Na)、镍(Ni)和锌(Zn)的含量
【标准年】:2003
【页码】:8P;A4
【总页数】:8
【标准分类号】:中国标准分类法H82; 国际标准分类法29.045
【主题词】:金属; 锌; 高纯度; 质谱学; 含量测定; 试验; 钠; 硝酸; 分析; 半导体工艺; ICP;纯净水; 铜; 微量元素; 化学分析和试验; 铝; 半导体; 液体; 镍; 半导体工程; 钴; 材料; 微量元素分析;定义; analysis; semiconductor engineering; semiconductors; zinc; cobalt; trace elements; sodium;aluminium; liquids; copper; icp; definition; determination of content; testing; metals; nitric acid;definitions; mass spectrometry; nickel; high-purity; superpurity water; materials; chemical analysisand testing; trace element analysis; semiconductor technology
5. 国外标准
记录号: 49687
【标准号】:DIN EN 14107-2003
【标准名称】:Fat and oil derivatives - Fatty acid methylesters (FAME) - Determination ofphosphorus content by inductively coupled plasma (ICP) emission spectrometry; German version EN14107:2003
【标准其他名称】:脂肪和油的衍生物.脂肪酸甲基酯(FAME).用感应耦合等离子体(ICP)发射光谱法测定磷含量
【标准年】:2003
【页码】:10P;A4
【总页数】:10
【主题词】:液体; 食品; FAME; 含量测定; 测定; 试验; 微分; 化学分析和试验; 含量; 脂肪酸甲酯;磷; 定义; 油; 脂肪酸; 动物油; 光谱测定法; 实验室间试验; 植物油; 磷含量; 分析; ICP; 脂肪; 甲酯;Analysis; Animal oils; Chemical analysis and testing; Content; Definition; Definitions; Derivativeof oil; Determination; Determination of content; FAME; Fats; Fatty acid methylesters; Fatty acids;Food products; ICP; Inter-laboratory tests; Liquid; Methyl esters; Oils; Phosphorus; Phosphoruscontent; Spectrometry; Testing; Vegetable oils
6. 国外标准
记录号: 51316
【标准号】:DIN 51086-2-2004
【标准名称】:Testing of oxidic raw materials and materials for ceramics, glass and glazes -Part 2: Determination of Ag, As, B, Ba, Be, Bi, Ca, Cd, Ce, Co, Cr, Cu, Er, Eu, Fe, La, Mg, Mn, Mo,Nd, Ni, P, Pb, Pr, S, Sb, Se, Sn, Sr, Ti, V, W, Y, Yb, Zn, Zr by optical emission spectrometry withinductively coupled plasma (ICP OES)
【标准其他名称】:氧化原材料及陶瓷、玻璃和釉料用材料的试验.用感应耦合等离子体光学发射光谱法测定Ag、As、B、Ba、Be、Bi、Ca、Cd、Ce、Co、Cr、Cu、Er、Eu、Fe、La、Mg、Mn、Mo、Nd、Ni、P、Pb、Pr、S、Sb、Se、Sn、Sr、Ti、V、W、Y、Yb、Zn和Zr
【标准年】:2004
【页码】:20P;A4
【总页数】:20
【标准分类号】:中国标准分类法Q30; 国际标准分类法81.060.10; 81.040.10
【主题词】:玻璃; 陶瓷; 试验; 材料; 原材料; 分析; 化学分析和试验; 釉料; 化学元素; 氧化物;含量测定; 计量学; 发射分光光度测定法; ICP; 材料试验; 定量分析; chemical analysis and testing;glazes; quantitative analysis; determination of content; emission spectrophotometry; analysis;oxides; materials testing; icp; testing; metrology; raw materials; materials; ceramics; chemicalelements; glass
7. 国外标准
记录号: 69528
【标准号】:ISO 11535-1998
【标准名称】:Iron ores - Determination of various elements - Inductively coupled plasmaatomic emission spectrometric method
【标准其他名称】:铁矿石 各种元素的测定 电感耦合等离子体原子放射光谱法
【标准年】:1998
【页码】:25P;A4
【总页数】:25
【标准分类号】:中国标准分类法D31; 国际标准分类法73.060.10
【主题词】:镉; 磷; 光谱测定法; 锰; 钛; 金属矿; 化学分析和试验; 铁矿石; 铝; 硅; 含量测定;感应耦合等离子体; 镁; chemical analysis and testing; aluminium; icp; phosphorus; iron ores;determination of content; manganese; cadmium; spectrometry; magnesium; silicon; metalliferousminerals; titanium
