主题:【转帖】如何在2min内找到所需电化学基础知识 -- 电 化 学 辞 海 !
浏览0 回复19 电梯直达
云中漫步
下面这个网站是电化学百科全书,你在2min内找到所需电化学基础知识,贴出来与所有同行共勉。
http://electrochem.cwru.edu/ed/dict.htm
东临碣石,以观沧海
Electrochemistry Dictionary
Simple and brief definitions of words and phrases used often in electrochemistry. In some cases, a second paragraph provides further information for the "more scientifically minded."
Revision date: August 26, 2006.
您可能想找: 烟气监测(CEMS)/烟气分析仪 询底价
zlmdianfenxi
jinmozhai
jinmozhai
heer3014854
key2dream
silverash
zjf216
zzmqh
飞翔
mantolo
