主题:【分享】和大家共享一封我的稿件的录用信!
浏览0 回复24 电梯直达
flysky
该帖子已被luqinhua设置为精华;
第一篇文章经过一次修改,
十天后接到编辑部的来信,
接受了,
呵呵,把来信拿出来和大家共享一下!
祝大家元旦节快乐!
Dear Prof. ***(我导师):
  I am pleased to inform you that your revised manuscript, "************************************************", is now acceptable for publication in *********** in its current form. The comments of the referee(s) who reviewed your manuscript are included at the bottom of this letter.
    The paper will now go into production and you will receive a galley proof by e-mail in due course. Once you have corrected the proof, the paper will then be published on-line via ****** ahead of its appearance in the printed journal.
patric
何当奇
何当奇
flysky
原文由 redanqi 发表:
But, Why the receiption of this letter is for your mentor??
mentor是指导师吧,
因为通讯作者是导师啊!
芝兰
wanghf0821
舒衫游鹭
guozhen611
何当奇
原文由 flysky 发表:
原文由 redanqi 发表:
mentor是指导师吧,
因为通讯作者是导师啊!
为什么自己的论文还要加上通讯作者导师??我没有发表过论文
flysky
一般发表国外的文章都是这样,
要有大人物在后面,
且国外主要看的是通讯作者,
通讯作者一般是比较有名的人士!
学生发表文章,最后的修改定稿都是导师的贡献,
还有你这篇稿件适合投到什么级别的刊物上,
一般是导师决定,你可以推荐!
