原文由 hzz314 发表:
In the material recorded and read by phase change between crystal and amorphous phase caused electromagnetic beam irradn., the recording layer contains Sb, Te, and elements A and B, in which local structures around A are almost the same and that around B are different before and after the phase change. The material is suited for high linear seed and high d. recording and shows good durability and storage stability.
high linear seed是什么意思
原文由 redanqi 发表:原文由 hzz314 发表:
你这个句子有错误吧
原文由 redanqi 发表:
这个地方也有问题。
