翻译第二篇.是关于钛酸钡陶瓷消解的,大家给提提意见
CERAMICS OF BARIUM TITANATE
Publication: Chemical analysis by Inductively Coupled Plasma Atomic Emission Spectrometry of semiconducting ceramics of barium titanate doped with various metal oxides
Authors:
Field: Ceramic
Elements: Al, Ca, Co, Cr, Cu, Fe, K, Li, Mg, Mn, Na, Nb, Ni, P, Pb, Si, Sr, W, Zn, Zr
The sample was crushed and milled down to a grain size < 30 µm in a tungsten carbide mortar.
Three decomposition methods were used.
Decomposition with HCl under pressure
The powdered sample (0.2 g) was treated in a PTFE-lined pressure vessel with 5 ml of HCl. Total dissolution requires 14 h at 160 °C. The solution was diluted to 100 ml with distilled water.
Fusion with Na2CO3
The sample (0.2 g) was mixed with 2.0 g of Na2CO3 in a platinum crucible and fused by heating in a Mekker burner for 30 min. After cooling, it was introduced carefully in a 250-mL beaker containing 100 ml of 1+9 (v/V) HCl and gently heated until the fused sample was dissolved. The solution was completely transferred to a 200 ml volumetric flask and diluted to volume with 1 +9 (v/v) HCl.
Fusion with Li 2B4 O7
The sample (0.2 g) was mixed with 2.0 g of Li 2B4 O7 in a porcelain crucible, and then transferred to a graphite crucible. The mixture was fused in a muffle furnace at 1100 °C for 20 min. The melt was then carefully and quickly poured into a 400-mL beaker containing 100 ml of 1 + 24 (v/v) HNO3 . The contents were stirred with a teflon-covered magnetic bar, on top of a magnetic stirrer until the melt dissolved. The solution was diluted to 200 ml with 1 + 24 (v/v) HNO3.
钛酸钡陶瓷
应用:利用ICP 化学分析含有各种金属氧化物钛酸钡半导体陶瓷
作者:Juan C Farinas, Maria F. Barba
领域:陶瓷业
分析元素:Al, Ca, Co, Cr, Cu, Fe, K, Li, Mg, Mn, Na, Nb, Ni, P, Pb, Si, Sr, W, Zn, Zr
将样品在炭化钨研钵碾碎并研磨至粒度小于30 µm
三种分解方法可以使用
用盐酸加压消解
粉末样品(0.2g) 在聚四氟乙烯压力容器加5ml HCL 被处理,整个消解需要在160°C温度下
14小时,溶液加蒸馏水稀释至100ml
用 Na2CO3熔融
0.2g 的样品与2.0g Na2CO3混合在白金坩埚内,在Mekker burner(?加热灯)加热熔融30分
钟,冷却后,小心倒入装有100ml HCL(1+9 v/V)的250ml烧杯中,缓慢加热至熔融样品溶解。
将溶液完整的转移到200ml容量瓶并用HCL(1+9 v/V)稀释定容。
用Li 2B4 O7熔融
0.2g 的样品与2.0g Li 2B4 O7混合在瓷坩埚内,然后移至石墨坩埚,在马氟炉内1100 °C
下混合物熔融 20分钟,然后熔融物小心快速的被倒入一个加有100ml(1+24 v/v) HNO3的400ml
烧杯中,用特氟隆磁棒搅拌混合物,直到磁棒顶端的熔融物溶解,溶液用1 + 24 (v/v) HNO3稀释
定容200ml.
