摘要:检测人员的能力和经验是保证检测工作质量的首要前提,人员对比是检测人员技能水平的最佳方法。本文采用实验室内部人员比对方法根据《NYT 761-2008 蔬菜和水果中有机磷、有机氯、拟除虫菊酯和氨基甲酸酯类农药多残留的测定》中的方法一来检测西葫芦中三唑磷和甲基对硫磷的残留。结果表明,上述两项比对项目,其线性系数大于0.99,在0.12mg/kg添加水平下,三唑磷回收率在65.8%-93.3%之间;甲基对硫磷回收率在63.3%-90.8%之间。
关键词:气相色谱法;人员比较;西葫芦;三唑磷;甲基对硫磷;
Abstract:The ability and experience of testing personnel is the firstprerequisite to ensure the quality of testing work. In this paper, internallaboratory personnel comparison method was adopted to detect the residues oftriazophos and methyl parathion in zucchini according to the method in NYT761-2008 determination of multiple residues of organophosphorus,organochlorine, pyrethroids and carbamate pesticides in vegetables and fruits.The results showed that the linear coefficient of the above two comparison itemswas greater than 0.99, and the recovery rate of triazophos was between 65.8%and 93.3% at the addition level of 0.12mg/kg. The recovery of methyl parathionranged from 63.3% to 90.8%.
Keywords:Gas chromatography; Personnelcomparison; pumpkin; Triazophos; Methylparathion;
前柱出峰时间RT | 后柱出峰时间RT | |
三唑磷 | 25.182 | 18.297 |
甲基对硫磷 | 15.228 | 13.787 |
W=(V1×V3×A×ρ)/(V2×AS×m).....................................................................(1)
式中符号:
ρ-标准溶液中农药的质量浓度,单位为毫克每升(mg/L);
A-样品溶液中被测农药的峰面积;
AS-农药标准溶液中被测农药的峰面积;
V1-提取溶剂总体积,单位为毫升(mL);
V2-吸取出用于检测的提取溶剂的体积,单位为毫升(mL);
V3-样品溶液定容体积,单位为毫升(mL);
m-试样的质量,单位为克(g)。
| 三唑磷 | 甲基对硫磷 | ||||||||||
| AS | V1 | V2 | V3 | m | A | AS | V1 | V2 | V3 | m | A |
人员1 | 398.494 | 50 | 10 | 5 | 25 | 435.289 | 484.255 | 50 | 10 | 5 | 25 | 446.927 |
398.494 | 50 | 10 | 5 | 25 | 539.513 | 484.255 | 50 | 10 | 5 | 25 | 549.355 | |
398.494 | 50 | 10 | 5 | 25 | 533.382 | 484.255 | 50 | 10 | 5 | 25 | 542.288 | |
人员2 | 398.494 | 50 | 10 | 5 | 25 | 545.644 | 484.255 | 50 | 10 | 5 | 25 | 601.920 |
398.494 | 50 | 10 | 5 | 25 | 282.019 | 484.255 | 50 | 10 | 5 | 25 | 311.105 | |
398.494 | 50 | 10 | 5 | 25 | 815.400 | 484.255 | 50 | 10 | 5 | 25 | 906.262 | |
人员3 | 398.494 | 50 | 10 | 5 | 25 | 435.289 | 484.255 | 50 | 10 | 5 | 25 | 453.276 |
398.494 | 50 | 10 | 5 | 25 | 521.121 | 484.255 | 50 | 10 | 5 | 25 | 540.125 | |
398.494 | 50 | 10 | 5 | 25 | 502.728 | 484.255 | 50 | 10 | 5 | 25 | 520.590 | |
人员4 | 398.494 | 50 | 10 | 5 | 25 | 647.931 | 484.255 | 50 | 10 | 5 | 25 | 666.395 |
398.494 | 50 | 10 | 5 | 25 | 584.401 | 484.255 | 50 | 10 | 5 | 25 | 638.746 | |
398.494 | 50 | 10 | 5 | 25 | 589.152 | 484.255 | 50 | 10 | 5 | 25 | 650.766 | |
人员5 | 398.494 | 50 | 10 | 5 | 25 | 674.391 | 484.255 | 50 | 10 | 5 | 25 | 749.964 |
398.494 | 50 | 10 | 5 | 25 | 723.63 | 484.255 | 50 | 10 | 5 | 25 | 749.960 | |
398.494 | 50 | 10 | 5 | 25 | 648.242 | 484.255 | 50 | 10 | 5 | 25 | 701.072 |
| 三唑磷(添加浓度0.12mg/kg) | 甲基对硫磷(添加浓度0.12mg/kg) | ||||||||||
| 检测浓度 | 平均浓度 | 回收率(%) | 平均回收率(%) | RSD(%) | 线性 方程 | 检测浓度 | 平均浓度 | 回收率(%) | 平均回收率(%) | RSD(%) | 线性 方程 |
人员 1 |
0.071 |
0.082 |
59.2 |
68.3 |
11.6 |
Y=6014.74486+4.67411(x=含量ng/ul,y=峰面积),相关性为0.99900 |
0.067 |
0.077 | 55.8 |
64.2 |
10.9 |
Y=6836.46347-12.96837(x=含量ng/ul,y=峰面积),相关性为0.99472 |
0.088 | 73.3 | 0.082 | 68.33 | |||||||||
0.087 | 72.5 | 0.081 | 67.5 | |||||||||
人员 2 | 0.089 |
0.089 | 74.2 |
74.2 |
48.6 | 0.089 |
0.0897 | 74.2 |
74.8 |
49.1 | ||
0.046 | 38.3 | 0.046 | 38.3 | |||||||||
0.133 | 110.8 | 0.134 | 111.7 | |||||||||
人员 3 | 0.071 |
0.079 | 59.2 |
65.8 |
9.29 | 0.068 |
0.076 | 56.7 |
63.3 |
8.99 | ||
0.085 | 70.8 | 0.081 | 67.5 | |||||||||
0.082 | 68.3 | 0.078 | 65.0 | |||||||||
人员 4 | 0.110 |
0.101 | 91.2 |
84.2 |
7.73 | 0.099 |
0.097 | 82.5 |
80.8 |
2.06 | ||
0.096 | 80.0 | 0.095 | 79.2 | |||||||||
0.097 | 80.8 | 0.097 | 80.8 | |||||||||
人员 5 | 0.110 |
0.112 | 98.2 |
93.3 |
5.58 | 0.111 |
0.109 | 92.5 |
90.8 |
3.72 | ||
0.119 | 99.2 | 0.111 | 92.5 | |||||||||
0.107 | 89.2 | 0.104 | 86.7 |
4讨论
本次人员对比虽然涉及的指标单一,但是从一定程度上反映了此次参加检测人员的水平,人员可根据此次对比进行分析,总结,相互交流经验与心得体会,探讨检测过程中存在的问题,提升自身检测水平,以提高检测数据的可靠性。
