Mixing Directions:Thoroughly mix 1.25 to 10 pounds of MGA 200 Premix (Type A Medicated Article) per ton of non-medicated feed to prepare a Type C medicated feed containing 0.25 to 2.0 grams of melengestrol acetate per ton. The following table may be used as a guide in determining the amount of MGA 200 Premix (Type A Medicated Article) to be added to prepare a ton of Type C medicated feed.
Type B medicated feeds containing 4 to 10 grams melengestrol acetate per ton may be manufactured by thoroughly mixing 20 to 50 lbs of MGA 200 Premix with 1980 to 1950 lbs of non-medicated feed. Labeling for such Type B feeds shall contain directions for manufacturing Type C medicated feeds containing 0.25 to 2.0 grams melengestrol acetate per ton (0.125-1.0 mg/lb). The Type C medicated feed, containing melengestrol acetate, must be top dressed on grain or roughage or mixed with a complete ration at the rate of 0.5 to 2.0 pounds per head per day.
Good manufacturing practice regulations must be adhered to in manufacturing feeds containing MGA 200.
制备的操作方法:每吨没有加药的饲料与1.25至10磅本品混合,制备得到含甲烯雌醇乙酸酯0.25至2.0克每吨的C型加药饲料。参照下表,可以确定MGA200预混剂的量制备C型加药饲料。
每吨B型药物饲料含有4至10克的甲烯雌醇乙酸酯,它是由20至50磅的MGA 200预混剂与1980至1950磅的无药饲料充分混合制成的。标号为B型的药物饲料应该包含制造甲烯雌醇乙酸酯含量为0.125-1.0 毫克/磅的C型药物饲料的方法。经过过筛除去粗谷物的C型饲料的使用量是0.5至2.0磅/头/日。
生产系列的MGA 200的饲料必须按照GMP的法规操作。
