主题:【求助】翻译highly evolved melts that added Re, Cu and S
skysnow520
These differences resulted from contrasting melt percolation styles between the two areas. Lianshan was affected by extensive percolation of sulfur undersaturated melts that removed Re, Os and S, while Panshishan experienced interaction with low degree or highly evolved melts that added Re, Cu and S, but had no affect on Os abundances.不知如何翻译,求各位大侠指点.
pseudoctor
好像是地质方便的东东,俺就乱翻一哈了:
这些(含量?丰度?)差别是由于两个地区不同的岩浆浸润方式行为引起的。连山(?)受到了硫欠饱和岩浆的充分浸润,去除了Re,Os和S;而盘石山只受到了低度或高进化岩浆的作用,增加了Re,Cu和S,但对Os的丰度没有影响。
