主题:【原创】代谢组学:Metabonomics代谢物组学:metabolomics,一个新的概念
浏览0 回复3 电梯直达
闲鹤野云
该帖子已被happyjyl设置为精华;
Metabonomics的最初定义是就生物系统对生理和病理刺激以及基因改变的代谢应答的定量测定(“the  quantitative  measurement  of  the  multi-parametric  metabolic  response  of  living  systems  to  pathophysiological  stimuli  or  genetic  modifications”).
闲鹤野云
我们认为这个定义现在可以更广泛地表述为:代谢组学是关于定量描述生物内源性代谢物质的整体及其对内因和外因变化应答规律的科学  (“Metabonomics  is  the  branch  of  science  concerned  with  the  quantitative  understandings  of  the  metabolite  complement  of  integrated  living  systems  and  its  dynamic  responses  to  the  changes  of  both  endogenous  factors  (such  as  physiology  and  development)  and  exogenous  factors  (such  as  environmental  factors  and  xenobiotics).”).
闲鹤野云
其中心任务包括  (1)  对内源性代谢物质的整体及其动态变化规律进行检测,量化和编录,(2)  确定此变化规律和生物过程的有机联系.  Metabolomics存在多个定义,但其精髓是:对一个生物系统的细胞在给定时间和给定条件下所有小分子代谢物质的定量分析(the  quantitative  measurement  of  all  low  molecular  weight  metabolites  in  an  organism's  cells  at  a  specified  time  under  specific  environmental  conditions).  因此,metabolomics可以译作“代谢物组学”.  不难看出,前者是对生物系统进行的整体和动态的认识  (不仅关心代谢物质的整体也关注其动态变化规律),而后者强调分析而且是个静态的认识概念.  因此可以认为,metabolomics是metabonomics的一个组成部分  (参看定义).  近年又有人提出了“dynamic  metabolomics”的概念,这个概念所表达的含义十分接近“metabonomics”本身的含义.  所以,可以预见,随着这门新兴学科的发展和更深入讨论,这两个概念必将趋向一致.
闲鹤野云
This is new to me and if you like to know more about metabonomics, please visit the following site.
http://www.instrument.com.cn/bbs/shtml/20070621/884648/
